    NPM problem "EBADENGINE" which I fail to solve
    19 Posts 3 Posters 33.7k Views 3 Watching
    • I
      Ix @sdetweil
      Hello @sdetweil and thank you for your fast answer!
      I tried and pasted your commands in my terminal. Sadly, it didn’t work…
      Here’s what it says:
      mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ node -v
      hash -r
      node -v
      v18.18.0
      v18.18.0
      mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ sudo npm ci
      npm warn EBADENGINE Unsupported engine {
      npm warn EBADENGINE   package: '@stylistic/eslint-plugin@2.1.0',
      npm warn EBADENGINE   required: { node: '^18.18.0 || ^20.9.0 || >=21.1.0' },
      npm warn EBADENGINE   current: { node: 'v18.17.1', npm: '10.7.0' }
      npm warn EBADENGINE }
      npm warn EBADENGINE   package: '@stylistic/eslint-plugin-js@2.1.0',
      npm warn EBADENGINE   package: 'eslint-visitor-keys@4.0.0',
      npm warn EBADENGINE   package: '@stylistic/eslint-plugin-jsx@2.1.0',
      npm warn EBADENGINE   package: '@typescript-eslint/utils@7.9.0',
      npm warn EBADENGINE   required: { node: '^18.18.0 || >=20.0.0' },
      npm warn EBADENGINE   package: '@stylistic/eslint-plugin-ts@2.1.0',
      npm warn EBADENGINE   package: '@typescript-eslint/scope-manager@7.9.0',
      npm warn EBADENGINE   package: '@typescript-eslint/types@7.9.0',
      npm warn EBADENGINE   package: '@typescript-eslint/typescript-estree@7.9.0',
      npm warn EBADENGINE   package: '@typescript-eslint/visitor-keys@7.9.0',
      npm warn EBADENGINE   package: 'espree@10.0.1',
      > mmm-publictransporthafas@2.1.1 prepare
      > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
      added 436 packages, and audited 437 packages in 43s
      155 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      It’s as if it doesn’t recognize my used version of node…
        MMRIZE @Ix
        @Ix
        Install recent nodejs.
        I don’t know how you have installed the current version of nodejs. So I cannot give you an exact advice.
        Generally I prefer to manage node version with nvm
        I S 2 Replies Last reply Reply Quote 0
        • I
          Ix @MMRIZE
          @MMRIZE said in NPM problem "EBADENGINE" which I fail to solve:
          Hey @MMRIZE 👋
          I used the following command:
          curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.7/install.sh | bash
          which I found here
          this is “nvm” isn’t it?
            sdetweil @MMRIZE
            @MMRIZE 1st line of 1st included message image shows his nvm command
            says using 18.18.0
            the npm ci says using 18.17.1
            try npm i
            I use n, which is a nodejs version of nvm
            sudo mpn install n
            n version
            n list
            n --help
            I 2 Replies Last reply Reply Quote 0
            • I
              Ix @sdetweil
              @sdetweil said in NPM problem "EBADENGINE" which I fail to solve:
              try npm I
              also tried this. same result :-/
              • I
                Ix @sdetweil
                sudo mpn install n
                n version
                n list
                I also tried this.
                Here are the results:
                mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n list
                node/22.2.0
                mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n version
                  Error: invalid version 'version'
                  sdetweil @Ix
                  @Ix version is the one you want to use
                  n 18
                  n 18.18
                  need sudo to change, as it write to /usr/local/bin which is protected
                  (as as nvm does)
                  see
                  n --help
                  • I
                    Ix @sdetweil
                    I already tried and changed my used version to v18.18 via nvm (what obviously didn’t work)
                    Now I installed “n” and tried again with your method.
                    mirror@raspberrypi:~/MagicMirror/modules $ sudo n 18.18
                      installing : node-v18.18.2
                           mkdir : /usr/local/n/versions/node/18.18.2
                           fetch : https://nodejs.org/dist/v18.18.2/node-v18.18.2-linux-arm64.tar.xz
                         copying : node/18.18.2
                    /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                       installed :  (with npm 9.8.1)
                    There is an error: “Datei oder Verzeichnis nicht gefunden” which translates into “File or directory not found” (Sry for my German OS 😅)
                    so there is another issue
                      sdetweil @Ix
                      @Ix said in NPM problem "EBADENGINE" which I fail to solve:
                      does that directory exist?
                      I’ve never had any problem with n, on windows, linux or mac.
                      do a
                      which node
                      so we can see where it is coming from
                      • I
                        Ix @sdetweil
                        yes I think:
                        mirror@raspberrypi:~/MagicMirror/modules $ cd /usr/local/bin
                        mirror@raspberrypi:/usr/local/bin $ ls
                        corepack  node  npm  npx
                        node is colored green in this ls
                          sdetweil @Ix
                          @Ix note its NOT usr/local/BIN its usr/local/N
                          (uppercase fore emphasis here)
                          • I
                            Ix @sdetweil
                            do a
                            which node
                            here is the result from “a”:
                            mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n -a
                              Error: missing -a|--arch value
                            yeah, but see the error message I posted above: it seems to get the directory wrong as well. sry for me being a newbie in this case
                            I really appreciate you helping me here!
                            edit:
                            file is there:
                            mirror@raspberrypi:/usr/local/n/versions/node $ ls
                            18.18.2  22.2.0
                              sdetweil @Ix
                              @Ix no
                              do
                              which node
                              this will tell the path to the first executable it finds
                              on my pi4 with node (from n)
                              is says
                              which node
                              /usr/local/bin/node
                              on my x64 box with n 18
                              it says
                              which node
                              /usr/local/bin/node
                              • I
                                Ix @sdetweil
                                @Ix no
                                do
                                which node
                                ah I over read that.
                                here’s the result:
                                mirror@raspberrypi:/usr/local/n/versions/node $ which node
                                /home/mirror/.nvm/versions/node/v18.18.0/bin/node
                                well that’s a completely different path… so what should I do now?
                                  @Ix the module author says this is a bug in the lint checker…
                                  do this, in the module folder
                                  npm i @stylistic/eslint-plugin@1.8.1
                                  then npm install
                                  • I
                                    Ix @sdetweil
                                    THANK YOU! This did it, the module is working again, finally!
                                    You are the best 🙌
                                    /solved
                                      sdetweil @Ix
                                      @Ix not me… another user
                                      • I Ix has marked this topic as solved on
