Default language changed after update
14 Posts 2 Posters 711 Views 2 Watching
  • S Away
    sdetweil @mrbaloo1337
    @mrbaloo1337
    2.28.0 is the current release number
    I want to know what version you were running prior to this one
    if you upgraded with my upgrade script, you can look in the log file
    ~/MagicMirror/installers/upgrade.log
      mrbaloo1337
      I was running on 2.27.0
      As far as I found out Sami is listed as “SE” and Swedish is “SV” in the ISO list for language. If that is for any help?
      This is the log file:
      Upgrade started - Wed Jul  3 13:27:27 CEST 2024
      system is Linux raspberrypi 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
      doing test run = true, NO updates will be applied!
      the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v20.9.0
      Installed Node version: v20.8.0
      Node should be upgraded.
      Node.js upgrade defered, doing test run
      Check current NPM installation ...
      NPM currently installed. Checking version number.
      Minimum npm version: V10.1.0
      Installed npm version: V10.1.0
      No npm upgrade necessary.
      saving custom.css
      remote name = origin
      upgrading from version 2.27.0 to 2.28.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
        (use "git pull" to update your local branch)
      Changes not staged for commit:
        (use "git add <file>..." to update what will be committed)
        (use "git restore <file>..." to discard changes in working directory)
      	modified:   package-lock.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
      	icscalender/
      	run-start.sh
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 1 local files that are different than the master repo
         package-lock.json
      save/restore files selection = n
      restoring package-lock.json from repo
      skipping restore for package-lock.json, doing test run
      test merge result rc='' , if empty, no conflicts
      skipping merge, only test run
      Checking for modules with removed libraries
      downloading dumpactivemodules script
      updating dependencies for active modules with package.json files
      	processing for module MMM-MQTT please wait
      	skipped processing for MMM-MQTT, doing test run
      	processing complete for module MMM-MQTT
      	processing for module MMM-CalendarExt3 please wait
      	skipped processing for MMM-CalendarExt3, doing test run
      	processing complete for module MMM-CalendarExt3
      restoring custom.css
      removing git alias
      Upgrade ended - Wed Jul  3 13:27:53 CEST 2024
        mrbaloo1337
        Hi again, for some magical reason i solved it.
        I had a module MMM-jast. Wich is the last one I installed before upgrade. For test, I took a backup of the config without that module.
        Everything was in Swedish again, added my config for that module in the backupconfig file. Everything works as before.
        I can´t point what caused the error, but now it works again. Maybe the file ended up corrupt in the upgrade…
        Thanks for your response and time, have a good day!
        S 1 Reply Last reply Jul 4, 2024, 1:53 PM Reply Quote 0
        • S Away
          @mrbaloo1337 very interesting. we don’t touch the config file . I don’t copy/restore it.
          • S sdetweil has marked this topic as solved on Jul 4, 2024, 1:53 PM
          2 / 2
