    Default language changed after update
    14 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @mrbaloo1337
      @mrbaloo1337 sorry, I don’t understand your response.
      is the file good or bad?
      what mm version were you on?
      M 2 Replies Last reply
        mrbaloo1337 @sdetweil
        Sorry, it looks good as far as I can see. I the texts in that file is the only workning translations. For example:
        “FEELS”: “Känns som {DEGREE}”,
        That´s a correct translation and works in Weather module, but weekdays is in Sami. See picture below.
        That´s the same problem for every module. Hope you understand what I mean :)
        I think that the connection to “sv” is broken and points to Sami instead of Swedish.
          Sorry missed, it is version 2.28.0
            @mrbaloo1337 I meant before this release.
            M 1 Reply Last reply
              No issues before upgrade, is it possible to downgrade to previous version?
                @mrbaloo1337 yes, but, I asked you to tell me what that version was.
                I am out of the house for another hour
                  I wrote that earlier, it is 2.28.0.
                  No worries, if you have any suggestions to my problem I will wait :)
                  On Saturday I leave for vacation so I hope it will be solved until that, otherwise I can´t sleep
                    @mrbaloo1337
                    2.28.0 is the current release number
                    I want to know what version you were running prior to this one
                    if you upgraded with my upgrade script, you can look in the log file
                    ~/MagicMirror/installers/upgrade.log
                      mrbaloo1337
                      I was running on 2.27.0
                      As far as I found out Sami is listed as “SE” and Swedish is “SV” in the ISO list for language. If that is for any help?
                      This is the log file:
                      Upgrade started - Wed Jul  3 13:27:27 CEST 2024
                      system is Linux raspberrypi 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
                      the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
                      Minimum Node version: v20.9.0
                      Installed Node version: v20.8.0
                      Node should be upgraded.
                      Node.js upgrade defered, doing test run
                      Minimum npm version: V10.1.0
                      Installed npm version: V10.1.0
                      No npm upgrade necessary.
                      saving custom.css
                      remote name = origin
                      upgrading from version 2.27.0 to 2.28.0
                      fetching latest revisions
                      git fetch rc=0
                      current branch = master
                      On branch master
                      Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
                        (use "git pull" to update your local branch)
                        (use "git add <file>..." to update what will be committed)
                        (use "git restore <file>..." to discard changes in working directory)
                      	modified:   package-lock.json
                      Untracked files:
                        (use "git add <file>..." to include in what will be committed)
                      	icscalender/
                      	run-start.sh
                      no changes added to commit (use "git add" and/or "git commit -a")
                      there are 1 local files that are different than the master repo
                         package-lock.json
                      save/restore files selection = n
                      restoring package-lock.json from repo
                      skipping restore for package-lock.json, doing test run
                      test merge result rc='' , if empty, no conflicts
                      skipping merge, only test run
                      downloading dumpactivemodules script
                      updating dependencies for active modules with package.json files
                      	processing for module MMM-MQTT please wait
                      	skipped processing for MMM-MQTT, doing test run
                      	processing complete for module MMM-MQTT
                      	processing for module MMM-CalendarExt3 please wait
                      	skipped processing for MMM-CalendarExt3, doing test run
                      	processing complete for module MMM-CalendarExt3
                      restoring custom.css
                      removing git alias
                      Upgrade ended - Wed Jul  3 13:27:53 CEST 2024
                        mrbaloo1337
                        Hi again, for some magical reason i solved it.
                        I had a module MMM-jast. Wich is the last one I installed before upgrade. For test, I took a backup of the config without that module.
                        Everything was in Swedish again, added my config for that module in the backupconfig file. Everything works as before.
                        I can´t point what caused the error, but now it works again. Maybe the file ended up corrupt in the upgrade…
                        Thanks for your response and time, have a good day!
                          @mrbaloo1337 very interesting. we don’t touch the config file . I don’t copy/restore it.
