    Default language changed after update
    14 Posts 2 Posters 2.5k Views 2 Watching
      sdetweil @mrbaloo1337
      @mrbaloo1337 can you check the ~/MagicMirror/translations/sv.json file
        mrbaloo1337
        This is what that file contains. Seems to be the only thing that is correct translated. Anything else will be in Sami.
        If I check in the translation file the row for Swedish is: “sv: “translations/sv.json”, // Svenska”
        	"LOADING": "Laddar …",
        	"DAYBEFOREYESTERDAY": "",
        	"YESTERDAY": "I går",
        	"TODAY": "I dag",
        	"TOMORROW": "I morgon",
        	"DAYAFTERTOMORROW": "I övermorgon",
        	"RUNNING": "Slutar",
        	"EMPTY": "Inga kommande händelser.",
        	"WEEK": "Vecka {weekNumber}",
        	"N": "N",
        	"NNE": "NNO",
        	"NE": "NO",
        	"ENE": "ONO",
        	"E": "Ö",
        	"ESE": "OSO",
        	"SE": "SO",
        	"SSE": "SSO",
        	"S": "S",
        	"SSW": "SSV",
        	"SW": "SV",
        	"WSW": "VSV",
        	"W": "V",
        	"WNW": "VNV",
        	"NW": "NV",
        	"NNW": "NNV",
        	"FEELS": "Känns som {DEGREE}",
        	"UPDATE_NOTIFICATION": "MagicMirror² uppdatering finns tillgänglig.",
        	"UPDATE_NOTIFICATION_MODULE": "Uppdatering finns tillgänglig av {MODULE_NAME} modulen.",
        	"UPDATE_INFO_SINGLE": "Denna installation ligger {COMMIT_COUNT} commit steg bakom {BRANCH_NAME} grenen.",
        	"UPDATE_INFO_MULTIPLE": "Denna installation ligger {COMMIT_COUNT} commits steg bakom {BRANCH_NAME} grenen."
          @mrbaloo1337 sorry, I don’t understand your response.
          is the file good or bad?
          what mm version were you on?
            mrbaloo1337 @sdetweil
            Sorry, it looks good as far as I can see. I the texts in that file is the only workning translations. For example:
            “FEELS”: “Känns som {DEGREE}”,
            That´s a correct translation and works in Weather module, but weekdays is in Sami. See picture below.
            That´s the same problem for every module. Hope you understand what I mean :)
            I think that the connection to “sv” is broken and points to Sami instead of Swedish.
              Sorry missed, it is version 2.28.0
                @mrbaloo1337 I meant before this release.
                  No issues before upgrade, is it possible to downgrade to previous version?
                    @mrbaloo1337 yes, but, I asked you to tell me what that version was.
                    I am out of the house for another hour
                      I wrote that earlier, it is 2.28.0.
                      No worries, if you have any suggestions to my problem I will wait :)
                      On Saturday I leave for vacation so I hope it will be solved until that, otherwise I can´t sleep
                        @mrbaloo1337
                        2.28.0 is the current release number
                        I want to know what version you were running prior to this one
                        if you upgraded with my upgrade script, you can look in the log file
                        ~/MagicMirror/installers/upgrade.log
                          mrbaloo1337
                          I was running on 2.27.0
                          As far as I found out Sami is listed as “SE” and Swedish is “SV” in the ISO list for language. If that is for any help?
                          This is the log file:
                          Upgrade started - Wed Jul  3 13:27:27 CEST 2024
                          system is Linux raspberrypi 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
                          the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
                          Minimum Node version: v20.9.0
                          Installed Node version: v20.8.0
                          Node should be upgraded.
                          Node.js upgrade defered, doing test run
                          Minimum npm version: V10.1.0
                          Installed npm version: V10.1.0
                          No npm upgrade necessary.
                          saving custom.css
                          remote name = origin
                          upgrading from version 2.27.0 to 2.28.0
                          fetching latest revisions
                          git fetch rc=0
                          current branch = master
                          On branch master
                          Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
                            (use "git pull" to update your local branch)
                            (use "git add <file>..." to update what will be committed)
                            (use "git restore <file>..." to discard changes in working directory)
                          	modified:   package-lock.json
                          Untracked files:
                            (use "git add <file>..." to include in what will be committed)
                          	icscalender/
                          	run-start.sh
                          no changes added to commit (use "git add" and/or "git commit -a")
                          there are 1 local files that are different than the master repo
                             package-lock.json
                          save/restore files selection = n
                          restoring package-lock.json from repo
                          skipping restore for package-lock.json, doing test run
                          test merge result rc='' , if empty, no conflicts
                          skipping merge, only test run
                          downloading dumpactivemodules script
                          updating dependencies for active modules with package.json files
                          	processing for module MMM-MQTT please wait
                          	skipped processing for MMM-MQTT, doing test run
                          	processing complete for module MMM-MQTT
                          	processing for module MMM-CalendarExt3 please wait
                          	skipped processing for MMM-CalendarExt3, doing test run
                          	processing complete for module MMM-CalendarExt3
                          restoring custom.css
                          removing git alias
                          Upgrade ended - Wed Jul  3 13:27:53 CEST 2024
                            mrbaloo1337
                            Hi again, for some magical reason i solved it.
                            I had a module MMM-jast. Wich is the last one I installed before upgrade. For test, I took a backup of the config without that module.
                            Everything was in Swedish again, added my config for that module in the backupconfig file. Everything works as before.
                            I can´t point what caused the error, but now it works again. Maybe the file ended up corrupt in the upgrade…
                            Thanks for your response and time, have a good day!
                              @mrbaloo1337 very interesting. we don’t touch the config file . I don’t copy/restore it.
