    odd module load behaviour after upgrading to 2.28
    5 Posts 4 Posters 744 Views 4 Watching
    • D
      david6461
      Hello,
      I upgraded to the latest 2.28 a couple days ago. I’m running my magicmirror on a raspberry pi 4. I noticed that the cpu was running higher than it was in the previous version so after a quick investigation here is what I found:
      I have multiple instances of mmm-touchbutton, I noticed that in the console.log message I have in the start function showed up a bunch of times I found that the number of messages is N^2 so if there are 2 instances of the module there are 4 messages generated from the start function if there are 3 instances there are 9 messages and so on.
      I added logging to some other modules and found the same issue so this is not a module specific issue.
      Any ideas?
      karsten13K wishmaster270W 2 Replies Last reply Reply Quote 0
        @wishmaster270
        This fix is now part of next release
        • karsten13K
          karsten13 @david6461
          @david6461
          tested this with the content of the config.js.sample, there are 2 weather instances in the config and I see 2 messages in the dev console
          • wishmaster270W
            wishmaster270 Module Developer @david6461
            @david6461
            I am running version 2.28 of MagicMirror with multiple instances of MMM-TouchButtons and multiple instances of a couple of other of my modules.
            I can’t confirm the problem.
            No double messages and no increased CPU usage.
            Are you sure you did not start a second instance of MagicMirror?
            • karsten13K karsten13 referenced this topic on
              sdetweil @wishmaster270
              @wishmaster270 lets try this fix
              in the MM/js folder do
              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror/fixloading/js/app.js >app.js
              then stop and restart mm.
              this adds a hash to see if we are already loading or loaded the node_helper for this module
                @wishmaster270
