    iFrame blank when displaing http://<ipaddress LMS server>:9000/material
    27 Posts 3 Posters 3.8k Views 3 Watching
      stephanvdplas @sdetweil
      @sdetweil said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
      @stephanvdplas said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
      Set-Cookie header didn’t specify a “SameSite” attribute and was defaulted to “SameSite=Lax”
      Ok, I don’t KNOW for certain, but our cors proxy might work there
      change the url in the iframe config to
      http://localhost:MM_PORT/cors?
      the rest like this
      // the url
      url=http://www.test.com/path?param1=value1 // example
      // if there are headers, skip if not
      &sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2
      make sure quotes around the url string’’
      It doesn’t work. Now there are no errors, but it only shows an empty frame.
      In the Preview tab, it shows {{snackbar.msg}}
      [24-09-18 22:33:38.8839] Slim::Utils::Misc::msg (1319) Warniing : [22:33:38.8838] “my” variable $mobile masks earlier declaration in same scope at (eval 5777) line 46.
      This warning is also seen in the debug log of LMS server, also when I open the 192.168.3.8/material on a browser on a windows machine (where the site is loading correctly).
        stephanvdplas @stephanvdplas
        @stephanvdplas There is another thing:
        In the preview tab of the content it shows: Failed to load response data: Connection is closed, can’t dispatch pending call to Network.getResponseBody
          sdetweil @stephanvdplas
          @stephanvdplas now I am out of my knowledge range.
          @karsten13 maybe has more skill here…
          • karsten13K Offline
            karsten13 @sdetweil
            sorry, no. Maybe google has some findings.
            karsten13K S 2 Replies Last reply Reply Quote 0
              karsten13 @karsten13
              you could try adding
                      electronOptions: {
                              webPreferences: { webSecurity: false },
              in config.js
                stephanvdplas @karsten13
                @karsten13 good option. I tried it (actually I placed the option directly in the electron.js script) but it doesn’t change the situation at all.
                  karsten13 @stephanvdplas
                  @stephanvdplas
                  I can only guess without having the debug case …
                  You can google and try changing electronOptionsDefaults and/or electronSwitchesDefaults in js/electron.js if you find something …
                    @karsten13 I am quite sure about having the config right:
                    	let electronSwitchesDefaults = ["autoplay-policy", "no-user-gesture-required"];
                    	app.commandLine.appendSwitch(...new Set(electronSwitchesDefaults, config.electronSwitches));
                    	let electronOptionsDefaults = {
                    		width: electronSize.width,
                    		height: electronSize.height,
                    		icon: "mm2.png",
                    		x: 0,
                    		y: 0,
                    		darkTheme: true,
                    		webPreferences: {
                    			contextIsolation: true,
                    			nodeIntegration: false,
                    			zoomFactor: config.zoom,
                    			webSecurity: false
                    		backgroundColor: "#000000"
                    	// DEPRECATED: "kioskmode" backwards compatibility, to be removed
                    	// settings these options directly instead provides cleaner interface
                    	if (config.kioskmode) {
                    		electronOptionsDefaults.kiosk = true;
                    	} else {
                    		electronOptionsDefaults.show = false;
                    		electronOptionsDefaults.frame = false;
                    		electronOptionsDefaults.transparent = true;
                    		electronOptionsDefaults.hasShadow = false;
                    		electronOptionsDefaults.fullscreen = true;
                    	const electronOptions = Object.assign({}, electronOptionsDefaults, config.electronOptions);
                    	// Create the browser window.
                    	mainWindow = new BrowserWindow(electronOptions);
                    So the webSecurity line is the only thing I added/changed.
                      sorry, my point is you have to google the error with the keyword “electron” and check if you find something which you can test
                        @karsten13 sorry to report that there is no other possibility than to revert back to electron 30.0.0
                        After this, the iFrame works again. After re-installing 31.0.0, it is broken again.
                        So no I have implemented this workaround.
                        sudo npm install electron@30.0.0
                        this command saved my life mirror
                        • 2 / 3
