    iFrame blank when displaing http://<ipaddress LMS server>:9000/material
    27 Posts 3 Posters 3.8k Views 3 Watching
      sdetweil @stephanvdplas
      @stephanvdplas unrelated to your problem is your solution technique.
      we provide access to these settings in config.js so you DON’T edit our code, as this causes update problems.
        stephanvdplas @sdetweil
        @sdetweil said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
        ok understood. But but both ways don’t work. Only thing that helps is reverting the installation of electron to 30.0.0.
          @stephanvdplas i understand, looks like something changed in 31, which can be a bug as well.
          you’ve got a workaround in the near term.
          id open an issue on the MagicMirror github page with the error and a link to this topic so we don’t lose it.
          finding a test environment will be the tough thing
          karsten13K S 2 Replies Last reply Reply Quote 0
          • karsten13K Offline
            karsten13 @sdetweil
            no, we don’t need another issue we cannot solve.
            The problem is chromium which is becoming stricter with every release and with every new electron version you get a new chromium version:
            electron	Chromium
            31.4.0		126.0.6478.23
            31.3.1		126.0.6478.185
            31.3.0		126.0.6478.183
            31.2.0		126.0.6478.127
            31.1.0		126.0.6478.114
            31.0.2		126.0.6478.61
            31.0.0		126.0.6445.0
            30.1.0		124.0.6367.243
            30.0.9		124.0.6367.233
            30.0.8		124.0.6367.230
            30.0.7		124.0.6367.221
            30.0.5		124.0.6367.207
            30.0.4		124.0.6367.201
            30.0.3		124.0.6367.119
            30.0.2		124.0.6367.91
            30.0.1		124.0.6367.60
            30.0.0		124.0.6323.0
            Maybe related to this changed in Chromium 125.
            We have to deal with this and downgrading chromium (indirect by downgrading electron) is no real solution.
              sdetweil @karsten13
              @karsten13 said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
              and how do you proose we do that with all the other things on our plate.
              documenting the issue so we can work on ‘dealing’ with it. is the only way in my opinion
                karsten13 @sdetweil
                I won’t stop you from opening an issue …
                • S stephanvdplas has marked this topic as solved on
                  Off course I’m willing to help with that. Just PM if you need to test something or if I can help set up a test environment.
                  • 3 / 3
