    PIR wake up automatically!
    14 Posts 4 Posters 3.2k Views 4 Watching
      sdetweil @Sceetch
      @Sceetch this info is provided in the startup message of MagicMirror
      if you are using pm2 to auto launch MagicMirror, then the pm2 command
      pm2 logs --lines=xxx
      where xxx is the number of most recent lines to display, and defaults to 15
        siujd2001
        I am having the same issue, which just started happening yesterday. It seems like the loop is 3 minutes or less, with the MMM-PIR timer set at 60 seconds to turn off screen.
        I’m not running MM automatically via pm2.
        I have added “vc4.force_hotplug=1” to the end of /boot/cmdline.txt
        Raspbian ver 11 bullseye
        MagicMirror version 2.29.0
          Sceetch @sdetweil
          if i do your code, i get these datas:
          PM2 | 2024-10-15T20:29:52: PM2 log: Node.js version : 20.8.0
          PM2 | 2024-10-15T20:29:52: PM2 log: Current arch : arm
          PM2 | 2024-10-15T20:29:52: PM2 log: PM2 home : /home/pi/.pm2
          PM2 | 2024-10-15T20:29:52: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid
          PM2 | 2024-10-15T20:29:52: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock
          PM2 | 2024-10-15T20:29:52: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock
          PM2 | 2024-10-15T20:29:52: PM2 log: Application log path : /home/pi/.pm2/logs
          PM2 | 2024-10-15T20:29:52: PM2 log: Worker Interval : 30000
          PM2 | 2024-10-15T20:29:52: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2
          PM2 | 2024-10-15T20:29:52: PM2 log: Concurrent actions : 2
          PM2 | 2024-10-15T20:29:52: PM2 log: SIGTERM timeout : 1600
          PM2 | 2024-10-15T20:29:52: PM2 log: ===============================================================================
          PM2 | 2024-10-15T20:29:52: PM2 log: [Watch] Start watching MagicMirror
          PM2 | 2024-10-15T20:29:52: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2 | 2024-10-15T20:29:52: PM2 log: App [MagicMirror:0] online
          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
          0|MagicMir | [2024-10-15 20:30:10.964] [LOG] Create new calendarfetcher for url:. Edited: moderator - Interval: 604800000
          0|MagicMir | [2024-10-15 20:30:11.292] [LOG] requesting:https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json
          0|MagicMir | [2024-10-15 20:30:11.331] [LOG] [MMM-Pir] Version: 1.5.3 rev: 240701
          0|MagicMir | [2024-10-15 20:30:11.333] [LOG] [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library)
          0|MagicMir | [2024-10-15 20:30:11.446] [LOG] [MMM-Pir] [LIB] [PIR] Started!
          0|MagicMir | [2024-10-15 20:30:11.449] [LOG] [MMM-Pir] [LIB] [SCREEN] Mode 9: xrandr (primary display) – Rotation: left
          0|MagicMir | [2024-10-15 20:30:11.473] [LOG] [MMM-Pir] Started!
          0|MagicMir | [2024-10-15 20:30:11.900] [LOG] MMM-DWD-Pollen: Success loading
          0|MagicMir | [2024-10-15 20:30:11.931] [LOG] [MMM-OpenWeatherForecast] 15-Oct-24 20:30 ** ERROR ** Error: Request failed with status code 401
          0|MagicMir | [2024-10-15 20:30:12.086] [INFO] System information:
          0|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false
          0|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
          0|MagicMir | ### VERSIONS: electron: 29.4.2; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.4.1
          0|MagicMir | ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
          0|MagicMir | [2024-10-18 19:33:19.104] [INFO] Calendar-Fetcher: Broadcasting 209 events from. Edited: moderator
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | [1441:1015/203007.468295:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.469114:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.469703:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.470376:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.470857:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.471246:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.471864:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.472289:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.473545:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.473975:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.474361:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1441:1015/203007.474628:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|MagicMir | [1039:1018/193452.138762:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [1039:1018/193452.146069:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [1039:1018/193452.150739:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMirror | [1039:1018/193549.175898:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMirror | [1039:1018/193549.241698:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMirror | [1039:1018/193549.246287:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMirror | [1039:1018/193634.176330:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMirror | [1039:1018/193634.183421:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMirror | [1039:1018/193634.186706:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
            sdetweil @Sceetch
            @Sceetch said in PIR wake up automatically!:
            I have seen troubles reported with mode zero.
            i dont use this myself
