    PIR wake up automatically!
    14 Posts 4 Posters 4.6k Views 4 Watching
      Sceetch @wishmaster270
      @wishmaster270
      Thx for your answer.
      I saw your Information on the end.
      But I can’t find the related .txt file under path
      /boot/firmware/cmdline.txt
      There is not a folder firmware inside.
      Do you have perhaps another solution??
      Thanks in advance
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @Sceetch
        @Sceetch
        on older OS Versions (i.e. Bullseye) the file is located under /boot/cmdline.txt
          @wishmaster270
          I saw this file, but there is no vc4.force_hotplug Parameter listet.
          Should I easily add it?
          wishmaster270W S 2 Replies Last reply
          • wishmaster270W
            @Sceetch Hi, yes, you will need to add it to the end of the single line that is in the file
              sdetweil @Sceetch
              @Sceetch did you resolve this?
                Sceetch @sdetweil
                Sorry for answering so late.
                The problem already exists.☹️
                To modify the Text file doesen’t solve the problem.
                I have actually no solution.
                Do u have another hint?
                  sdetweil @Sceetch
                  @Sceetch can you tell us the OS level you are on?
                  at the endof the startup messages with the latest version of MM is a list of the info we need
                  from my desktop system for example
                  [2024-10-15 01:09:31.337] [INFO]  System information:
                  ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                  ### OS:       platform: linux; distro: Ubuntu; release: 22.04.4 LTS; arch: x64; kernel: 5.15.0-122-generic
                  ### VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 22.9.0; npm: 10.8.3; pm2: 5.4.2
                  ### OTHER:    timeZone: Australia/Sydney; ELECTRON_ENABLE_GPU: undefined
                  on Bookworm,(latest) the PIM modes changed
                    Sceetch @sdetweil
                    thx for help.
                    for me its not clear where i can find the information?
                    Is it on the booting sequence for raspberry?
                      sdetweil @Sceetch
                      @Sceetch this info is provided in the startup message of MagicMirror
                      if you are using pm2 to auto launch MagicMirror, then the pm2 command
                      pm2 logs --lines=xxx
                      where xxx is the number of most recent lines to display, and defaults to 15
                        siujd2001
                        I am having the same issue, which just started happening yesterday. It seems like the loop is 3 minutes or less, with the MMM-PIR timer set at 60 seconds to turn off screen.
                        I’m not running MM automatically via pm2.
                        I have added “vc4.force_hotplug=1” to the end of /boot/cmdline.txt
                        Raspbian ver 11 bullseye
                        MagicMirror version 2.29.0
                          Sceetch @sdetweil
                          if i do your code, i get these datas:
                          PM2 | 2024-10-15T20:29:52: PM2 log: Node.js version : 20.8.0
                          PM2 | 2024-10-15T20:29:52: PM2 log: Current arch : arm
                          PM2 | 2024-10-15T20:29:52: PM2 log: PM2 home : /home/pi/.pm2
                          PM2 | 2024-10-15T20:29:52: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid
                          PM2 | 2024-10-15T20:29:52: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock
                          PM2 | 2024-10-15T20:29:52: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock
                          PM2 | 2024-10-15T20:29:52: PM2 log: Application log path : /home/pi/.pm2/logs
                          PM2 | 2024-10-15T20:29:52: PM2 log: Worker Interval : 30000
                          PM2 | 2024-10-15T20:29:52: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2
                          PM2 | 2024-10-15T20:29:52: PM2 log: Concurrent actions : 2
                          PM2 | 2024-10-15T20:29:52: PM2 log: SIGTERM timeout : 1600
                          PM2 | 2024-10-15T20:29:52: PM2 log: ===============================================================================
                          PM2 | 2024-10-15T20:29:52: PM2 log: [Watch] Start watching MagicMirror
                          PM2 | 2024-10-15T20:29:52: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2 | 2024-10-15T20:29:52: PM2 log: App [MagicMirror:0] online
                          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                          0|MagicMir | [2024-10-15 20:30:10.964] [LOG] Create new calendarfetcher for url:. Edited: moderator - Interval: 604800000
                          0|MagicMir | [2024-10-15 20:30:11.292] [LOG] requesting:https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json
                          0|MagicMir | [2024-10-15 20:30:11.331] [LOG] [MMM-Pir] Version: 1.5.3 rev: 240701
                          0|MagicMir | [2024-10-15 20:30:11.333] [LOG] [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library)
                          0|MagicMir | [2024-10-15 20:30:11.446] [LOG] [MMM-Pir] [LIB] [PIR] Started!
                          0|MagicMir | [2024-10-15 20:30:11.449] [LOG] [MMM-Pir] [LIB] [SCREEN] Mode 9: xrandr (primary display) – Rotation: left
                          0|MagicMir | [2024-10-15 20:30:11.473] [LOG] [MMM-Pir] Started!
                          0|MagicMir | [2024-10-15 20:30:11.900] [LOG] MMM-DWD-Pollen: Success loading
                          0|MagicMir | [2024-10-15 20:30:11.931] [LOG] [MMM-OpenWeatherForecast] 15-Oct-24 20:30 ** ERROR ** Error: Request failed with status code 401
                          0|MagicMir | [2024-10-15 20:30:12.086] [INFO] System information:
                          0|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false
                          0|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
                          0|MagicMir | ### VERSIONS: electron: 29.4.2; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.4.1
                          0|MagicMir | ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                          0|MagicMir | [2024-10-18 19:33:19.104] [INFO] Calendar-Fetcher: Broadcasting 209 events from. Edited: moderator
                          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                          0|MagicMir | [1441:1015/203007.468295:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.469114:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.469703:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.470376:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.470857:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.471246:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.471864:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.472289:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.473545:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.473975:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.474361:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1441:1015/203007.474628:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                          0|MagicMir | [1039:1018/193452.138762:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMir | [1039:1018/193452.146069:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMir | [1039:1018/193452.150739:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMirror | [1039:1018/193549.175898:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMirror | [1039:1018/193549.241698:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMirror | [1039:1018/193549.246287:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMirror | [1039:1018/193634.176330:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMirror | [1039:1018/193634.183421:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                          0|MagicMirror | [1039:1018/193634.186706:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
                            sdetweil @Sceetch
                            @Sceetch said in PIR wake up automatically!:
                            I have seen troubles reported with mode zero.
                            i dont use this myself
