Receive a HTTP request and subsequently wake up display and display alert/notification
14 Posts 3 Posters 960 Views 3 Watching
    MilkShake
    Oh well, succeded in turning the display on as well:
            module: "MMM-NotificationTrigger",
                    useWebhook: true,
                    triggers: [
                                    trigger: "SOMEONE_AT_THE_DOOR",
                                    fires: [
                                                    fire: "SHOW_ALERT",
                                                    exec: "vcgencmd display_power 1",
                                                    payload: {
                                                            title: "PORTEN",
                                                            message: "Der er nogen ved porten!",
                                                            timer: "20000",
    Last thing to do is to also play the doorbell. I need to configure the speaker on the rasp4 first.
      MilkShake @MMRIZE
      @MMRIZE said in Receive a HTTP request and subsequently wake up display and display alert/notification:
      @MilkShake said in Receive a HTTP request and subsequently wake up display and display alert/notification:
      It works when I include the notification in the URL like this:
      http://MMIP:8090/remote?action=NOTIFICATION&notification=SOMEONE_AT_THE_DOOR
      Simply, you can use this.
      http://MMIP:8090/webhook?notification=SOMEONE_AT_THE_DOOR
      That is the GET method.
      for the shellscript, your trial seems right, but you should take care for the path and the permission.
      I think this would be right. (It depends on your environment)
      exec: "bash /home/Kragh/monitor_on.sh",
      // OR
      exec: ". /home/Kragh/monitor_on.sh",
      Well, I got it working, sort off.
      I cannot get http://192.168.1.100:8090/webhook?action=notification=SOMEONE_AT_THE_DOOR to work. It returns a 200:OK but nothing is displayed.
      I have to use http://MMIP:8090/remote?action=NOTIFICATION&notification=SOMEONE_AT_THE_DOOR for it to work.
      M 1 Reply Last reply Oct 2, 2024, 11:46 AM Reply Quote 0
        MMRIZE @MilkShake
        read carefully.
          MilkShake
          read carefully.
          You are absolutely correct. Thanks for pointing it out.
          • S sdetweil has marked this topic as solved on Oct 5, 2024, 11:26 AM
          2 / 2
