    Receive a HTTP request and subsequently wake up display and display alert/notification
    14 Posts 3 Posters 5.0k Views 3 Watching
      MMRIZE @MilkShake
      @MilkShake
      What is the request body from the gate? “SHOW_ALERT”? I think it would be better to emit other dedicated custom notification other than “SHOW_ALERT”.
        sdetweil @MMRIZE
        @MMRIZE he is trying to get the alert module popup
          MilkShake @MMRIZE
          @MMRIZE said in Receive a HTTP request and subsequently wake up display and display alert/notification:
          @MilkShake
          It is just a webhook that is meant to get cached by MMM-NotificationTrigger module, that in turn should be able to send notifications to the Alert module.
            MMRIZE @MilkShake
            @MilkShake
            First, What request method and body is emitted from the gate?
            It should be something like;
            • endpoint : http://MYMM:8090/webhook
            • requestMethod : "POST"
            • requestHeader: "Content-type: application/json"
            • requestBody : (
              notification: "SOMEONE_AT_THE_DOOR"
            If you select “GET” as requestMethod, you may need to deliver the notification as parameter instead of requestBody JSON
            Then you can configure like this.
            	module: "MMM-NotificationTrigger",
            		useWebhook: true,
            		triggers: [
            				trigger: "SOMEONE_AT_THE_DOOR",
            				fires: [
            						fire: "SHOW_ALERT",
            						payload: {
            							title: "Someone arrives home",
            							message: "Welcome back home!",
            							timer: "10000",
              MilkShake @MMRIZE
              @MilkShake
              • requestBody : (
              		useWebhook: true,
              		triggers: [
              				fires: [
              						fire: "SHOW_ALERT",
              						payload: {
              							timer: "10000",
              Thanks man! I will try that out. I think the doorbird appliance is using application/json POST requests, even though that is hard to find in the documentation.
                MMRIZE @MilkShake
                @MilkShake
                Could you share the doc? Let’s look inside together.
                  MilkShake @MMRIZE
                  @MMRIZE All I have is this:
                  https://www.doorbird.com/downloads/manual_d10x_en_de.pdf
                  It works when I include the notification in the URL like this:
                  http://MMIP:8090/remote?action=NOTIFICATION&notification=SOMEONE_AT_THE_DOOR
                  That is sweet. Now I need to exec a shell script also.
                    MilkShake
                    Also, do you know the syntax for executing a shell script in MMM-NotificationTrigger?
                    I though it would be like this:
                                    useWebhook: true,
                                    triggers: [
                                                    fires: [
        fire: "SHOW_ALERT",
        exec: "home/Kragh/monitor_on.sh",
        payload: {
        title: "PORTEN",
        message: "Der er nogen ved porten!",
        timer: "10000",
                    monitor_on.sh is set as executionable.
                      MMRIZE @MilkShake
                      @MilkShake said in Receive a HTTP request and subsequently wake up display and display alert/notification:
                      Simply, you can use this.
                      http://MMIP:8090/webhook?notification=SOMEONE_AT_THE_DOOR
                      That is the GET method.
                      for the shellscript, your trial seems right, but you should take care for the path and the permission.
                      I think this would be right. (It depends on your environment)
                      exec: "bash /home/Kragh/monitor_on.sh",
                      // OR
                      exec: ". /home/Kragh/monitor_on.sh",
                        MilkShake
                        Oh well, succeded in turning the display on as well:
                                        useWebhook: true,
                                        triggers: [
                                                        fires: [
        fire: "SHOW_ALERT",
        exec: "vcgencmd display_power 1",
        payload: {
        title: "PORTEN",
        timer: "20000",
                        Last thing to do is to also play the doorbell. I need to configure the speaker on the rasp4 first.
                          MilkShake @MMRIZE
                          // OR
                          Well, I got it working, sort off.
                          I cannot get http://192.168.1.100:8090/webhook?action=notification=SOMEONE_AT_THE_DOOR to work. It returns a 200:OK but nothing is displayed.
                          I have to use http://MMIP:8090/remote?action=NOTIFICATION&notification=SOMEONE_AT_THE_DOOR for it to work.
                            MMRIZE @MilkShake
                            read carefully.
                              MilkShake
                              read carefully.
                              You are absolutely correct. Thanks for pointing it out.
