    Receive a HTTP request and subsequently wake up display and display alert/notification
    14 Posts 3 Posters 2.5k Views 3 Watching
      MilkShake
      I have been trying to display a notification on my MM upon the receival of a HTTP request that comes from my gate. When womeone pushes the button at the gate, the gate is able to do a HTTP request.
      It is setup to request: http://MYMM:8090/webhook
      When that is fired I receive a 200:OK.
      In my config I have:
            module: "MMM-NotificationTrigger",
              useWebhook:true,
              triggers:[
                  trigger: "SHOW_ALERT",
                  fires: [
                      fire:"SHOW_ALERT",
                      payload:{
                              "title": "PORTEN",
                              "message": "Der er nogen ved porten",
                              "timer":5000
      Can anyone point me in the right direction?
      Much appreciated :)
      Br,
      Lars
        MilkShake @MMRIZE
        @MMRIZE said in Receive a HTTP request and subsequently wake up display and display alert/notification:
        @MilkShake said in Receive a HTTP request and subsequently wake up display and display alert/notification:
        It works when I include the notification in the URL like this:
        http://MMIP:8090/remote?action=NOTIFICATION&notification=SOMEONE_AT_THE_DOOR
        Simply, you can use this.
        http://MMIP:8090/webhook?notification=SOMEONE_AT_THE_DOOR
        That is the GET method.
        for the shellscript, your trial seems right, but you should take care for the path and the permission.
        I think this would be right. (It depends on your environment)
        exec: "bash /home/Kragh/monitor_on.sh",
        // OR
        exec: ". /home/Kragh/monitor_on.sh",
        Well, I got it working, sort off.
        I cannot get http://192.168.1.100:8090/webhook?action=notification=SOMEONE_AT_THE_DOOR to work. It returns a 200:OK but nothing is displayed.
        I have to use http://MMIP:8090/remote?action=NOTIFICATION&notification=SOMEONE_AT_THE_DOOR for it to work.
          MMRIZE @MilkShake
          @MilkShake
          What is the request body from the gate? “SHOW_ALERT”? I think it would be better to emit other dedicated custom notification other than “SHOW_ALERT”.
            sdetweil @MMRIZE
            @MMRIZE he is trying to get the alert module popup
              MilkShake @MMRIZE
              @MilkShake
              It is just a webhook that is meant to get cached by MMM-NotificationTrigger module, that in turn should be able to send notifications to the Alert module.
                MMRIZE @MilkShake
                @MilkShake
                First, What request method and body is emitted from the gate?
                It should be something like;
                • endpoint : http://MYMM:8090/webhook
                • requestMethod : "POST"
                • requestHeader: "Content-type: application/json"
                • requestBody : (
                  notification: "SOMEONE_AT_THE_DOOR"
                If you select “GET” as requestMethod, you may need to deliver the notification as parameter instead of requestBody JSON
                Then you can configure like this.
                		useWebhook: true,
                		triggers: [
                				trigger: "SOMEONE_AT_THE_DOOR",
                				fires: [
                						fire: "SHOW_ALERT",
                						payload: {
                							title: "Someone arrives home",
                							message: "Welcome back home!",
                							timer: "10000",
                  MilkShake @MMRIZE
                  @MilkShake
                  • requestBody : (
                  		useWebhook: true,
                  		triggers: [
                  				fires: [
                  						fire: "SHOW_ALERT",
                  						payload: {
                  							timer: "10000",
                  Thanks man! I will try that out. I think the doorbird appliance is using application/json POST requests, even though that is hard to find in the documentation.
                    MMRIZE @MilkShake
                    @MilkShake
                    Could you share the doc? Let’s look inside together.
                      MilkShake @MMRIZE
                      @MMRIZE All I have is this:
                      https://www.doorbird.com/downloads/manual_d10x_en_de.pdf
                      That is sweet. Now I need to exec a shell script also.
                        MilkShake
                        Also, do you know the syntax for executing a shell script in MMM-NotificationTrigger?
                        I though it would be like this:
                                        useWebhook: true,
                                        triggers: [
                                                        fires: [
        fire: "SHOW_ALERT",
        exec: "home/Kragh/monitor_on.sh",
        payload: {
        title: "PORTEN",
        message: "Der er nogen ved porten!",
        timer: "10000",
                        monitor_on.sh is set as executionable.
                          MMRIZE @MilkShake
                          // OR
                            MilkShake
                            Oh well, succeded in turning the display on as well:
                                            useWebhook: true,
                                            triggers: [
                                                            fires: [
        fire: "SHOW_ALERT",
        exec: "vcgencmd display_power 1",
        payload: {
        title: "PORTEN",
        timer: "20000",
                            Last thing to do is to also play the doorbell. I need to configure the speaker on the rasp4 first.
                              MilkShake @MMRIZE
                              // OR
                                MMRIZE @MilkShake
                                read carefully.
                                  MilkShake
                                  read carefully.
                                  You are absolutely correct. Thanks for pointing it out.
