    update-script.sh hangs after "saving custom.css"
    14 Posts 2 Posters 1.9k Views 3 Watching
    • X Offline
      xIExodusIx @sdetweil
      df -k shows:
      Filesystem 1K-blocks Used Available Use% Mounted on
      udev 1667704 0 1667704 0% /dev
      tmpfs 388200 1444 386756 1% /run
      /dev/sda2 61387080 7699368 50549572 14% /
      tmpfs 1940984 34100 1906884 2% /dev/shm
      tmpfs 5120 16 5104 1% /run/lock
      /dev/sda1 522230 77064 445166 15% /boot/firmware
      tmpfs 388196 40 388156 1% /run/user/1000
      • X Offline
        I send you the upgrade.log in GitHuB.
        I hope this will help.
          sdetweil @xIExodusIx
          @xIExodusIx thanks i replied there.
          i do not know yet. i am away from my system the rest of the day. i would not try anything else, just let MagicMirror run.
          if you have the update message . you can disable the updatenotification module in config .js
          add
          disabled:true,
          after the module: line
            bug in my script, fixed.
