    update-script.sh hangs after "saving custom.css"
    14 Posts 2 Posters 2.5k Views 3 Watching
    • X Offline
      xIExodusIx @sdetweil
      @sdetweil Hi,
      I try to send the upgrade log.
      ![upgrade.log.jpg](Input file contains unsupported image format)
      If you recieved it, simply delete “.jpg”
      Otherwise I don’t know how to uploade it.
        sdetweil @xIExodusIx
        @xIExodusIx here you can only attach pictures.
        you could paste the text into a post, but probably better to attach to an issue on the github repo for the scripts
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          Hi, I’ll give it a try.
          • X Offline
            I Can’t login to GitHub, they sends me confirmation codes to an old inexisting eMail-Address that never arrives. I wrote to the GitHub support, but they dosn’t answer until today.
            I copy the lines. See below
            • false
            • SAVEIFS=’
            • IFS=’
            • echo
            • tee -a /home/pi/MagicMirror/installers/upgrade.log
            • ‘[’ -f git_active_lock ‘]’
            • ‘[’ 0 == 1 ‘]’
            • cd /home/pi/MagicMirror
            • cd css
            • ‘[’ -f custom.css ‘]’
            • echo ‘saving custom.css’
              saving custom.css
            • cp -p custom.css save_custom.css
            • cd -
              ++ alias git
            • save_alias=
              ++ git branch
              ++ cut -d ’ ’ -f2
              ++ grep ‘*’
            • current_branch=master
            • ‘[’ master ‘!=’ master ‘]’
            • remote_user=MagicMirrorOrg
              ++ LC_ALL=C
              ++ git remote -v
              ++ grep -m1 .com/M
              ++ awk ‘{print $1}’
            • remote=origin
            • ‘[’ origin == upstream ‘]’
              ++ grep -m1 origin
              ++ git remote -v
              ++ awk -F/ ‘{print $4}’
            • ‘[’ MagicMirrorOrg == MichMich ‘]’
            • ‘[’ origin. ‘!=’ . ‘]’
            • echo remote name = origin
              ++ grep -m1 version
              ++ awk ‘-F"’ ‘{print $4}’
              ++ awk -F- ‘{print $1}’
              @xIExodusIx well, that makes no sense.
              there are at least 8 more easy commands after that one.
              the last one just wrote to the log
              is your disk space almost full?
              do
              df -k
              X 4 Replies Last reply Reply Quote 0
              • X Offline
                I’m now able again to login to GitHub. now I can send you the update.log if you still need it.
                • X Offline
                  No, the Pi starts from an USB-Stick with 64GB and it is freshly installed ther must be enough space left.
                  • X Offline
                    df -k shows:
                    Filesystem 1K-blocks Used Available Use% Mounted on
                    udev 1667704 0 1667704 0% /dev
                    tmpfs 388200 1444 386756 1% /run
                    /dev/sda2 61387080 7699368 50549572 14% /
                    tmpfs 1940984 34100 1906884 2% /dev/shm
                    tmpfs 5120 16 5104 1% /run/lock
                    /dev/sda1 522230 77064 445166 15% /boot/firmware
                    tmpfs 388196 40 388156 1% /run/user/1000
                    • X Offline
                      I send you the upgrade.log in GitHuB.
                      I hope this will help.
                        @xIExodusIx thanks i replied there.
                        i do not know yet. i am away from my system the rest of the day. i would not try anything else, just let MagicMirror run.
                        if you have the update message . you can disable the updatenotification module in config .js
                        add
                        disabled:true,
                        after the module: line
                          bug in my script, fixed.
