    update-script.sh hangs after "saving custom.css"
    14 Posts 2 Posters 2.6k Views 3 Watching
    • X Offline
      xIExodusIx
      Hello, I’m not really new to MagicMirror, trying to install and get it to run since MM 2.16.
      Now after a break time I tried again to get it run like I wish it. It runs but some of the Modules I like to have won’t run or runs not as aspected. So does the update-script.sh. It hangs after “saving custom.css”.
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
      Check current Node installation …
      Minimum Node version: v20.9.0
      Installed Node version: v20.9.0
      No Node.js upgrade necessary.
      Check current NPM installation …
      Minimum npm version: V10.1.0
      Installed npm version: V10.8.3
      No npm upgrade necessary.
      saving custom.css
      It dosen’t matter haw long I wait for that the script will continue, it won’t continue. I have to kill it by pressing “CTRL C”.
      Same behavior when I add “apply” or “force” to the script.
      I run MagicMirrror on a Raspbery Pi 4B with 8 GB Ram using latest Rasberry OS “Bookworm 64Bit”.
      Could someone please help?
        bug in my script, fixed.
          sdetweil @xIExodusIx
          @xIExodusIx can you post the upgrade.log
          ~/MagicMirror/installers/upgrade.log
          or open an issue on the script repo and attach the log there.
          i am the script author
          S X 2 Replies Last reply Reply Quote 0
            @xIExodusIx can you do the same script where it has -c
            add -x
            basch -c -x …
            rest of command
            you will get a lot of stuff to the screen. i need to see that last few lines above where it stops
            screen print or copy the lines
            X 1 Reply Last reply Reply Quote 0
            • X Offline
              xIExodusIx @sdetweil
              @sdetweil Hi,
              I try to send the upgrade log.
              ![upgrade.log.jpg](Input file contains unsupported image format)
              If you recieved it, simply delete “.jpg”
              Otherwise I don’t know how to uploade it.
                @xIExodusIx here you can only attach pictures.
                you could paste the text into a post, but probably better to attach to an issue on the github repo for the scripts
                • X Offline
                  Hi, I’ll give it a try.
                  • X Offline
                    I Can’t login to GitHub, they sends me confirmation codes to an old inexisting eMail-Address that never arrives. I wrote to the GitHub support, but they dosn’t answer until today.
                    I copy the lines. See below
                    • false
                    • SAVEIFS=’
                    • IFS=’
                    • echo
                    • tee -a /home/pi/MagicMirror/installers/upgrade.log
                    • ‘[’ -f git_active_lock ‘]’
                    • ‘[’ 0 == 1 ‘]’
                    • cd /home/pi/MagicMirror
                    • cd css
                    • ‘[’ -f custom.css ‘]’
                    • echo ‘saving custom.css’
                      saving custom.css
                    • cp -p custom.css save_custom.css
                    • cd -
                      ++ alias git
                    • save_alias=
                      ++ git branch
                      ++ cut -d ’ ’ -f2
                      ++ grep ‘*’
                    • current_branch=master
                    • ‘[’ master ‘!=’ master ‘]’
                    • remote_user=MagicMirrorOrg
                      ++ LC_ALL=C
                      ++ git remote -v
                      ++ grep -m1 .com/M
                      ++ awk ‘{print $1}’
                    • remote=origin
                    • ‘[’ origin == upstream ‘]’
                      ++ grep -m1 origin
                      ++ git remote -v
                      ++ awk -F/ ‘{print $4}’
                    • ‘[’ MagicMirrorOrg == MichMich ‘]’
                    • ‘[’ origin. ‘!=’ . ‘]’
                    • echo remote name = origin
                      ++ grep -m1 version
                      ++ awk ‘-F"’ ‘{print $4}’
                      ++ awk -F- ‘{print $1}’
                      @xIExodusIx well, that makes no sense.
                      there are at least 8 more easy commands after that one.
                      the last one just wrote to the log
                      is your disk space almost full?
                      do
                      df -k
                      X 4 Replies Last reply Reply Quote 0
                      • X Offline
                        I’m now able again to login to GitHub. now I can send you the update.log if you still need it.
                        • X Offline
                          No, the Pi starts from an USB-Stick with 64GB and it is freshly installed ther must be enough space left.
                          • X Offline
                            df -k shows:
                            Filesystem 1K-blocks Used Available Use% Mounted on
                            udev 1667704 0 1667704 0% /dev
                            tmpfs 388200 1444 386756 1% /run
                            /dev/sda2 61387080 7699368 50549572 14% /
                            tmpfs 1940984 34100 1906884 2% /dev/shm
                            tmpfs 5120 16 5104 1% /run/lock
                            /dev/sda1 522230 77064 445166 15% /boot/firmware
                            tmpfs 388196 40 388156 1% /run/user/1000
                            • X Offline
                              I send you the upgrade.log in GitHuB.
                              I hope this will help.
                                @xIExodusIx thanks i replied there.
                                i do not know yet. i am away from my system the rest of the day. i would not try anything else, just let MagicMirror run.
                                if you have the update message . you can disable the updatenotification module in config .js
                                add
                                disabled:true,
                                after the module: line
