update-script.sh hangs after "saving custom.css"
14 Posts 2 Posters 462 Views 3 Watching
  • X Offline
    xIExodusIx
    Hello, I’m not really new to MagicMirror, trying to install and get it to run since MM 2.16.
    Now after a break time I tried again to get it run like I wish it. It runs but some of the Modules I like to have won’t run or runs not as aspected. So does the update-script.sh. It hangs after “saving custom.css”.
    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
    Check current Node installation …
    Minimum Node version: v20.9.0
    Installed Node version: v20.9.0
    No Node.js upgrade necessary.
    Check current NPM installation …
    Minimum npm version: V10.1.0
    Installed npm version: V10.8.3
    No npm upgrade necessary.
    saving custom.css
    It dosen’t matter haw long I wait for that the script will continue, it won’t continue. I have to kill it by pressing “CTRL C”.
    Same behavior when I add “apply” or “force” to the script.
    I run MagicMirrror on a Raspbery Pi 4B with 8 GB Ram using latest Rasberry OS “Bookworm 64Bit”.
    Could someone please help?
    S 1 Reply Last reply Oct 1, 2024, 1:00 PM Reply Quote 1
      bug in my script, fixed.
        sdetweil @xIExodusIx
        @xIExodusIx can you post the upgrade.log
        ~/MagicMirror/installers/upgrade.log
        or open an issue on the script repo and attach the log there.
        i am the script author
        S X 2 Replies Last reply Oct 1, 2024, 1:20 PM Reply Quote 0
          @xIExodusIx can you do the same script where it has -c
          add -x
          basch -c -x …
          rest of command
          you will get a lot of stuff to the screen. i need to see that last few lines above where it stops
          screen print or copy the lines
          X 1 Reply Last reply Oct 1, 2024, 1:24 PM Reply Quote 0
          • X Offline
            xIExodusIx @sdetweil
            @sdetweil Hi,
            I try to send the upgrade log.
            ![upgrade.log.jpg](Input file contains unsupported image format)
            If you recieved it, simply delete “.jpg”
            Otherwise I don’t know how to uploade it.
            S 1 Reply Last reply Oct 1, 2024, 1:22 PM Reply Quote 0
              @xIExodusIx here you can only attach pictures.
              you could paste the text into a post, but probably better to attach to an issue on the github repo for the scripts
              X 1 Reply Last reply Oct 1, 2024, 1:29 PM Reply Quote 0
              • X Offline
                Hi, I’ll give it a try.
                • X Offline
                  I Can’t login to GitHub, they sends me confirmation codes to an old inexisting eMail-Address that never arrives. I wrote to the GitHub support, but they dosn’t answer until today.
                  I copy the lines. See below
                  • false
                  • SAVEIFS=’
                  • IFS=’
                  • echo
                  • tee -a /home/pi/MagicMirror/installers/upgrade.log
                  • ‘[’ -f git_active_lock ‘]’
                  • ‘[’ 0 == 1 ‘]’
                  • cd /home/pi/MagicMirror
                  • cd css
                  • ‘[’ -f custom.css ‘]’
                  • echo ‘saving custom.css’
                    saving custom.css
                  • cp -p custom.css save_custom.css
                  • cd -
                    ++ alias git
                  • save_alias=
                    ++ git branch
                    ++ cut -d ’ ’ -f2
                    ++ grep ‘*’
                  • current_branch=master
                  • ‘[’ master ‘!=’ master ‘]’
                  • remote_user=MagicMirrorOrg
                    ++ LC_ALL=C
                    ++ git remote -v
                    ++ grep -m1 .com/M
                    ++ awk ‘{print $1}’
                  • remote=origin
                  • ‘[’ origin == upstream ‘]’
                    ++ grep -m1 origin
                    ++ git remote -v
                    ++ awk -F/ ‘{print $4}’
                  • ‘[’ MagicMirrorOrg == MichMich ‘]’
                  • ‘[’ origin. ‘!=’ . ‘]’
                  • echo remote name = origin
                    ++ grep -m1 version
                    ++ awk ‘-F"’ ‘{print $4}’
                    ++ awk -F- ‘{print $1}’
                  S 1 Reply Last reply Oct 1, 2024, 2:22 PM Reply Quote 0
                    @xIExodusIx well, that makes no sense.
                    there are at least 8 more easy commands after that one.
                    the last one just wrote to the log
                    is your disk space almost full?
                    do
                    df -k
                    X 4 Replies Last reply Oct 1, 2024, 2:34 PM Reply Quote 0
                    • X Offline
                      I’m now able again to login to GitHub. now I can send you the update.log if you still need it.
                      • X Offline
                        No, the Pi starts from an USB-Stick with 64GB and it is freshly installed ther must be enough space left.
