    Bookworm: MM not starting
    11 Posts 2 Posters 884 Views 2 Watching
      sdetweil @calimero
      @calimero said in Bookworm: MM not starting:
      backup MM folder
      use your install-script
      removed module and config-content from backup to new folder
      also, I have backup/restore scripts that will do that AND allow you to keep different versions, AND save on github
      NOT on local machine where it might be lost
      only saves the config, custom.css and a LIST of the modules (where from)
      on restore, reinstalls all the modules (in case node.js changed during the time between backup and restore)
      see
