    Bookworm: MM not starting
    11 Posts 2 Posters 1.6k Views 2 Watching
      sdetweil @calimero
      @calimero use pm2
      if you had used my install script this was a choice
      there is a separate script so yiu can add pm2 later
      see
        calimero @sdetweil
        @sdetweil Thank you for your reply.
        You’re talking about this script?
        Behaviour did not change after executing.
        │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
        │ 1 │ MagicMirror │ default │ 2.29.0 │ fork │ 3229 │ 3s │ 23 │ online │ 0% │ 2.6mb │ pi │ enabled │
        │ 0 │ mm │ default │ N/A │ fork │ 3285 │ 0s │ 3 │ online │ 0% │ 2.6mb │ pi │ disabled │
        pm2 log:
        1|MagicMirror | [2024-10-20 22:48:49.111] [LOG] Starting MagicMirror: v2.29.0
        1|MagicMirror | [2024-10-20 22:48:49.179] [LOG] Loading config …
        1|MagicMirror | [2024-10-20 22:48:49.185] [LOG] config template file not exists, no envsubst
        1|MagicMirror | [2024-10-20 22:48:50.448] [INFO] Checking config file /home/pi/MagicMirror/config/config.js …
        1|MagicMirror | [2024-10-20 22:48:50.667] [INFO] Your configuration file doesn’t contain syntax errors :)
        1|MagicMirror | [2024-10-20 22:48:50.670] [INFO] Checking modules structure configuration …
        1|MagicMirror | [2024-10-20 22:48:50.941] [ERROR] right is not defined
        Do you have a further advice? Thanks in advance!
          sdetweil @calimero
          @calimero said in Bookworm: MM not starting:
          pm2 log:
          looks lik you have a module in a wrong position
          C 2 Replies Last reply Reply Quote 0
            calimero @sdetweil
            @sdetweil Touché.
            U’re absolutely right. Just removed the handy PIR-script and installed PIR-Sensor-Lite and forgot the “”. My bad.
            But: Beaviour is like before. I can start the process and access the MM via Browser but it does not start on the local display.
            What works is:
            Browse the MM-IP from whitelistet IP. That’s nice but I’d like to have the MM just showing via autostart on the display which is attached to the PI:(
              calimero @sdetweil
              Perhaps I should have named the title “MM not showing” instead of “MM not starting”.
                sdetweil @calimero
                @calimero if you do
                pm2 stop all
                npm start
                does it come up?
                  calimero @sdetweil
                  Unfortunately not:
                  ozone_platform_x11.cc(245) Missing X server or $DISPLAY
                  env.cc(258)] The platform failed to initialize.
                  /home/pi/MagicMIrror/node_modules/electron/dist/electron exited with signal SIGSEGV
                    calimero
                    Nevermind -
                    my last two replys are not published yet.
                    Anyway - I read about a smiliar problem and tried the following:
                    • backup MM folder
                    • use your install-script
                    • removed module and config-content from backup to new folder
                    MM starts up as intended.
                    No idea, what was the issue exactly, but after your installation-script-usage it works as a charm.
                    Thanks for support!
                      sdetweil @calimero
                      @calimero glad you got it going.
                      as for your delayed posts
                      everyone with reputation below 2 has their posts reviewed. this to stop all the junk posts
                      i review every such post, and occasionally sleep! lol
                      please don’t double post
                        sdetweil @calimero
                        backup MM folder
                        also, I have backup/restore scripts that will do that AND allow you to keep different versions, AND save on github
                        NOT on local machine where it might be lost
                        only saves the config, custom.css and a LIST of the modules (where from)
                        on restore, reinstalls all the modules (in case node.js changed during the time between backup and restore)
                        see
                        https://github.com/sdetweil/MagicMirror-backup-restore
