Bookworm: MM not starting
11 Posts 2 Posters 675 Views 2 Watching
    calimero
    I just did a fresh install of MM under Bookwork (full version).
    If system launches to GUI I did not find any way of autostart MM in kiosk-mode browser.
    MM-service is starting, but I don’t get a local MM-GUI running.
    Trying this way had no success.
    No change if GUI is set to Wayland or X11.
    I remember an older version of MM which was just startable via PM2, npm start or service file.
    If I setup boot to CLI instead of GUI, MM also does not start because of an error that the GUI is needed.
    TL;DR: How can I autostart MM on a local display on a debian bookworm?
    Any advices are highly appreciated!
    S 1 Reply Last reply Oct 20, 2024, 8:30 PM Reply Quote 0
      calimero
      Nevermind -
      my last two replys are not published yet.
      Anyway - I read about a smiliar problem and tried the following:
      • backup MM folder
      • use your install-script
      • removed module and config-content from backup to new folder
      MM starts up as intended.
      No idea, what was the issue exactly, but after your installation-script-usage it works as a charm.
      Thanks for support!
      S 2 Replies Last reply Oct 21, 2024, 11:36 AM Reply Quote 0
        sdetweil @calimero
        @calimero use pm2
        if you had used my install script this was a choice
        there is a separate script so yiu can add pm2 later
        see
        C 1 Reply Last reply Oct 20, 2024, 8:51 PM Reply Quote 0
          calimero @sdetweil
          @sdetweil Thank you for your reply.
          You’re talking about this script?
          Behaviour did not change after executing.
          │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
          │ 1 │ MagicMirror │ default │ 2.29.0 │ fork │ 3229 │ 3s │ 23 │ online │ 0% │ 2.6mb │ pi │ enabled │
          │ 0 │ mm │ default │ N/A │ fork │ 3285 │ 0s │ 3 │ online │ 0% │ 2.6mb │ pi │ disabled │
          pm2 log:
          1|MagicMirror | [2024-10-20 22:48:49.111] [LOG] Starting MagicMirror: v2.29.0
          1|MagicMirror | [2024-10-20 22:48:49.179] [LOG] Loading config …
          1|MagicMirror | [2024-10-20 22:48:49.185] [LOG] config template file not exists, no envsubst
          1|MagicMirror | [2024-10-20 22:48:50.448] [INFO] Checking config file /home/pi/MagicMirror/config/config.js …
          1|MagicMirror | [2024-10-20 22:48:50.667] [INFO] Your configuration file doesn’t contain syntax errors :)
          1|MagicMirror | [2024-10-20 22:48:50.670] [INFO] Checking modules structure configuration …
          1|MagicMirror | [2024-10-20 22:48:50.941] [ERROR] right is not defined
          Do you have a further advice? Thanks in advance!
          S 1 Reply Last reply Oct 20, 2024, 9:06 PM Reply Quote 0
            sdetweil @calimero
            @calimero said in Bookworm: MM not starting:
            pm2 log:
            looks lik you have a module in a wrong position
            C 2 Replies Last reply Oct 20, 2024, 9:12 PM Reply Quote 0
              calimero @sdetweil
              @sdetweil Touché.
              U’re absolutely right. Just removed the handy PIR-script and installed PIR-Sensor-Lite and forgot the “”. My bad.
              But: Beaviour is like before. I can start the process and access the MM via Browser but it does not start on the local display.
              What works is:
              Browse the MM-IP from whitelistet IP. That’s nice but I’d like to have the MM just showing via autostart on the display which is attached to the PI:(
                calimero @sdetweil
                Perhaps I should have named the title “MM not showing” instead of “MM not starting”.
                S 1 Reply Last reply Oct 20, 2024, 10:53 PM Reply Quote 0
                  sdetweil @calimero
                  @calimero if you do
                  pm2 stop all
                  npm start
                  does it come up?
                  C 1 Reply Last reply Oct 21, 2024, 6:49 AM Reply Quote 0
                    calimero @sdetweil
                    Unfortunately not:
                    ozone_platform_x11.cc(245) Missing X server or $DISPLAY
                    env.cc(258)] The platform failed to initialize.
                    /home/pi/MagicMIrror/node_modules/electron/dist/electron exited with signal SIGSEGV
                      calimero
                      Nevermind -
                      • backup MM folder
                      Thanks for support!
                        sdetweil @calimero
                        @calimero glad you got it going.
                        as for your delayed posts
                        everyone with reputation below 2 has their posts reviewed. this to stop all the junk posts
                        i review every such post, and occasionally sleep! lol
                        please don’t double post
