    MMM-OpenWeatherForecast
    6 Posts 2 Posters 861 Views 2 Watching
      dcazman
      position right or left do make the entire MMM-OpenWeatherForecast module disappear.
      How do i make it fill the entire right side ?
      I tried to use custom css and added height but no change.
        sdetweil @dcazman
        @dcazman its not right or left
        its top_right or bottom_right
        instead of crashing, we now put out a message (in the startup messages) and skip that module if the position is unknown
        the official positions from the doc
        for css changes see the second link in my signature below for how to use the developers window elements tab
          dcazman @sdetweil
          @sdetweil To take the entire right side then do it with css?
            sdetweil @dcazman
            @dcazman yes, top_right, then make it taller.
            anything after that in top_right in config.js will be pushed off the page (beyond the fold, as its called)
              dcazman @sdetweil
              then why is height doing nothing ?
              .MMM-OpenWeatherForecast .module-content {
               width: 400px;
               height: 400px;
                sdetweil @dcazman
                @dcazman i don’t know, id have to see the css tree of styles (dev window)
                just because you set the outer container size does NOT mean the content inside will auto adjust
