    SIGINT error
    4 Posts 2 Posters 607 Views 2 Watching
    • R
      ReD1470
      Hi there,
      Tinkering can be fun, but is mostly frustrating.
      Working on my mirror hoping to get a physical button to work, i ran into this error
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      @sdetweil yes we have talked before, and yes I have tried the repair script using apply
      which worked great last time
      what changed after all was fine
      • tinkerd with python script to check if the button was working
      • disconnected the button to eliminate possible interference
      • raspian updates were installed
      • changed mm-carousel module version from barnabycolby to shbatm
      • several pi reboots
      let me know if you want more info
      or when you have the solution
      cheers!
      • R
        ReD1470 @sdetweil
        hey there,
        false alarm… i think. After the pi update the problem was gone
          sdetweil @ReD1470
          @ReD1470 what os version are you running on? do
          lsb_release -a
          • R
            ReD1470 @sdetweil
            hey there,
              sdetweil @ReD1470
              @ReD1470 awesome
