    MMM-CalendarExt3 - Calendar module. Hide calendar
    5 Posts 2 Posters 978 Views 2 Watching
      mrbaloo1337
      Hi!
      I’m using the MMM-CalendarExt3 and Calendar modules. Right now, I have a calendar that I only want to display in the CalendarExt module, not in the Calendar module. I’ve tried to hide it using EventTransformer but haven’t been able to solve the issue. Does anyone have an idea of what to do?
      Regards
        mrbaloo1337 @sdetweil
        @sdetweil That will hide the hole module. I just want to hide 1 of 4 calendars in default calender module.
        But maybe if I slash out the calendar and move the 3 I want to show to a new instance of the module with the position I want. I can try it out
          sdetweil @mrbaloo1337
          @mrbaloo1337 just comment out the position of the default calendar module
          add double slash before the position setting
          // position:
              @mrbaloo1337 yes separating like that will work
                mrbaloo1337
                Worked fine! Sometime the easiest way is the best solution. Thanks!
