    MMM-Pir
    34 Posts 5 Posters 6.2k Views 6 Watching
      sdetweil @gonzonia
      @gonzonia said in MMM-Pir:
      {“npm”:“10.9.0”,“node”:“v21.7.1”}
      you may have to close and open new shell
      or do
      hash -r
      to update the path
      • G Offline
        gonzonia @sdetweil
        @sdetweil Okay.
        I’ve run
        sudo npm install n -g
        sudo n 20
        hash -r
        then closed the terminal and reconnected.
        Went back into the MMM-Pir directory and tried running the setup again.
        Same problem
          sdetweil @gonzonia
          @gonzonia node -v
          returns what?
          • G Offline
            gonzonia @sdetweil
            pi@MagicMirror:~ $ node -v
            v21.7.1
              sdetweil @gonzonia
              @gonzonia weird… how did you upgrade to node 21?
              apt or nvm?
              G 1 Reply Last reply Reply Quote 1
              • G Offline
                gonzonia @sdetweil
                @sdetweil Honestly, I don’t remember. I think I installed nvm at one point to fix something else but I do run apt regularly to update everything
                  sdetweil @gonzonia
                  @gonzonia do nvm -v
                  n and nvm do the same thing
                  nvm is a bash script
                  n is a javascript app
                  • G Offline
                    gonzonia @sdetweil
                    $ nvm -v
                    0.39.7
                      sdetweil @gonzonia
                      @gonzonia ok, so you have nvm too
                      sudo nvm i 20
                      • G Offline
                        gonzonia @sdetweil
                        @sdetweil said in MMM-Pir:
                        sudo nvm i 20
                        sudo nvm i 20
                        sudo: nvm: command not found
                        • 3 / 4
