    MMM-Pir
    34 Posts 5 Posters 5.7k Views 6 Watching
    • G Offline
      gonzonia
      I was trying to update MMM-Pir and having some trouble so I decided, I’d rename the directory and start with a fresh install. I cloned the directory and followed the instructions with “npm run setup”. Apparently my node version is too high.
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: MMM-Pir@2.0.0
      npm error notsup Not compatible with your version of node/npm: MMM-Pir@2.0.0
      npm error notsup Required: {“node”:“>=20.9.0 <21 || >=22”}
      npm error notsup Actual: {“npm”:“10.8.3”,“node”:“v21.7.1”}
      Can I not use MMM-Pir now?
        sdetweil @gonzonia
        @gonzonia install node 20, MagicMirror has the same version restrictions, cause we found some problems w node 21
        sudo npm install n -g
        sudo n 20
        sudo is required here because they both update the /usr folder
        G 2 Replies Last reply Reply Quote 0
        • G Offline
          gonzonia @sdetweil
          @sdetweil Thanks!
          • G Offline
            gonzonia @sdetweil
            @sdetweil I did that and I still get the same problem. How do I make sure it uses the correct version?
            pi@MagicMirror:~/MagicMirror/modules/MMM-Pir $ sudo npm install n -g
            added 1 package in 5s
            pi@MagicMirror:~/MagicMirror/modules/MMM-Pir $ sudo n 20
                 copying : node/20.18.0
               installed : v20.18.0 (with npm 10.8.2)
            npm error notsup Required: {"node":">=20.9.0 <21 || >=22"}
            npm error notsup Actual:   {"npm":"10.9.0","node":"v21.7.1"}
              sdetweil @gonzonia
              @gonzonia said in MMM-Pir:
              {“npm”:“10.9.0”,“node”:“v21.7.1”}
              you may have to close and open new shell
              or do
              hash -r
              to update the path
              • G Offline
                gonzonia @sdetweil
                @sdetweil Okay.
                I’ve run
                sudo n 20
                hash -r
                then closed the terminal and reconnected.
                Went back into the MMM-Pir directory and tried running the setup again.
                Same problem
                  sdetweil @gonzonia
                  @gonzonia node -v
                  returns what?
                  • G Offline
                    gonzonia @sdetweil
                    pi@MagicMirror:~ $ node -v
                    v21.7.1
                      sdetweil @gonzonia
                      @gonzonia weird… how did you upgrade to node 21?
                      apt or nvm?
                      G 1 Reply Last reply Reply Quote 1
                      • G Offline
                        gonzonia @sdetweil
                        @sdetweil Honestly, I don’t remember. I think I installed nvm at one point to fix something else but I do run apt regularly to update everything
                        • 1 / 4
