MMM-Pir
I was trying to update MMM-Pir and having some trouble so I decided, I’d rename the directory and start with a fresh install. I cloned the directory and followed the instructions with “npm run setup”. Apparently my node version is too high.
npm error code EBADENGINE
npm error engine Unsupported engine
npm error engine Not compatible with your version of node/npm: MMM-Pir@2.0.0
npm error notsup Not compatible with your version of node/npm: MMM-Pir@2.0.0
npm error notsup Required: {“node”:“>=20.9.0 <21 || >=22”}
npm error notsup Actual: {“npm”:“10.8.3”,“node”:“v21.7.1”}Can I not use MMM-Pir now?
@gonzonia install node 20, MagicMirror has the same version restrictions, cause we found some problems w node 21
sudo npm install n -g sudo n 20sudo is required here because they both update the /usr folder
@sdetweil Thanks!
S sdetweil has marked this topic as solved on
@sdetweil I did that and I still get the same problem. How do I make sure it uses the correct version?
pi@MagicMirror:~/MagicMirror/modules/MMM-Pir $ sudo npm install n -g added 1 package in 5s pi@MagicMirror:~/MagicMirror/modules/MMM-Pir $ sudo n 20 copying : node/20.18.0 installed : v20.18.0 (with npm 10.8.2)npm error code EBADENGINE npm error engine Unsupported engine npm error engine Not compatible with your version of node/npm: MMM-Pir@2.0.0 npm error notsup Not compatible with your version of node/npm: MMM-Pir@2.0.0 npm error notsup Required: {"node":">=20.9.0 <21 || >=22"} npm error notsup Actual: {"npm":"10.9.0","node":"v21.7.1"} -
@sdetweil Okay.
I’ve runsudo npm install n -g sudo n 20 hash -rthen closed the terminal and reconnected.
Went back into the MMM-Pir directory and tried running the setup again.
Same problem -
@gonzonia node -v
returns what? -
pi@MagicMirror:~ $ node -v v21.7.1 -
@gonzonia weird… how did you upgrade to node 21?
apt or nvm? -
@sdetweil Honestly, I don’t remember. I think I installed nvm at one point to fix something else but I do run apt regularly to update everything
