    What's the correct way to remove any margins from a module?
    3 Posts 2 Posters 678 Views 2 Watching
    • R
      redink
      I am using MMM-CalendarExt3 with some fairly limited width. I’d like to remove any margins from it and have it go from edge to edge. In the past, I did this using custom.css, but it seemed hacky. I just tried setting the position to “fullscreen_below” and it removed the margins, but it’s sitting at the very top of the screen. How do I make it appear at the bottom of my screen with no margins or padding?
      • R
        redink @sdetweil
        Thanks, I ended up doing this in my custom.css
        #module_4_MMM-CalendarExt3
            margin-left: -40px;
            margin-right: -40px;
        It doesn’t seem like the best approach, but it works.
          sdetweil @redink
          @redink in main.css the module wrapper is defined like this
          .module {
            margin-bottom: var(--gap-modules);
          so you could override that
          .module_name(or class)  {
             margin-bottom: '0px';
          see the second link in my signature below on how to use the developers window elements tab to discover and test changes before copy/pasting them into custom.css
          R 1 Reply Last reply
          • R
            redink @sdetweil
                margin-left: -40px;
