    Idea how to power Raspberry Pi 3B and display controller board?
    4 Posts 2 Posters 990 Views 2 Watching
    • W Offline
      Wendy
      Any idea how I could power a Raspberry Pi 3B (5.1V 2.5A) and a B173RW01 V5 controller (12V 3A or 5A) board (which powers a display) with only one power supply behind a magic mirror? The thing is that it has to be as flat as possible. Is there some kind of power supply and split cable for micro USB and 5.5mm x 2.5mm DC power connector and the different voltages I listed?
      I could just use two power adapters/supplies but I only have one power outlet and I can’t fit a power socket behind the mirror :/
        sdetweil @Wendy
        @Wendy they make a little power converter (step down buck)
        12v in 5v out
        for example from Amazon
        • W Offline
          Wendy @sdetweil
          @sdetweil OK but how would you wire both the controller board and the raspberry pi? Could you suggest the whole setup? So which power supply connected to where and where is the step down connected to?
            sdetweil @Wendy
            @Wendy 12v from power supply to both display and converter in
            5v from converter out to pi
            with the appropriate pigtails for wire to device connectors as needed
            you could also power the pi thru the gpio pins
