    CalendarExt3Timeline disappeared
    4 Posts 2 Posters 1.4k Views 2 Watching
      mischag
      So, had CalendarExt3Timeline working fine. Would load, had all the symbols working and colours, and they matched what was showing in the CalendarExt3 module when loaded.
      Then, I’ve added MMM-Pages.
      I moved the CalendarExt3 to page 2 by using classes.
      I wanted CalendarExt3Timeline to show on page 3 using classes. But showing what was on Page 2’s calendar.
      Now, I can’t get the ‘Timeline’ module to show, anywhere? I thought it might be because it’s ‘position’ was the same as the weather module, but this is on a different page so shouldn’t be an issue?
      Any help would be greatly appreciated… Thanks
        sdetweil @mischag
        @mischag if you disable pages to make them both display, do they ?
        add
        disabled: true,
        to the MMM-pages
        config
        after the
        module: "MMM-pages",
        line
        did you have a typo in the classes string? dang computers are picky
          mischag @sdetweil
          @sdetweil Thanks for the reply.
          No, added that line in and it disabled pages, brought up all the modules that are across all the other pages on the home page, but still didn’t show…
            sdetweil @mischag
            @mischag ok, so I think you need to reduce the config the the two modules
            Calendar and ext3timeline
            Simplest is to add
            disabled: true,
            To each other module after its position line
            Then once you solve this, change true to false
