    Weather symbol missing
    9 Posts 2 Posters 436 Views 2 Watching
      dRagon
      There is a Rectangle before the temperature. it used to be a symbol showing the type of the weather. Does someone has any ideas?
        sdetweil @dRagon
        @dRagon open the developers window
        ctrl-shift-i
        select the console tab
        enter weath in the filter field
        what changed?
          dRagon @sdetweil
          this is what it looks like. the rectangle is still there
            sdetweil @dRagon
            @dRagon ok, remove the filter
              dRagon @sdetweil
                sdetweil @dRagon
                @dRagon hm, expected there to be a 404 error (not found)
                  dRagon
                  something was messed up with the css file
                  • D dRagon has marked this topic as solved on
                    dRagon @sdetweil
                    This post is deleted!
                      sdetweil @dRagon
                      @dRagon glad you found it!
