    MMM-Pir Monitor stays black instead of turning off completley
    6 Posts 2 Posters 796 Views 2 Watching
    • C
      Che
      I´ve updated my whole setup as I´ve missed out too many updates and decided to reset my SD Card and give it a fresh clean install.
      Mostly the mirror is back on track but I am still struggling with my PIR-Sensor. I have used the the older version EXT-Pir which isn´t supported anymore.
      Using this my monitor turned off completely. Now it only stays black.
      This was my older config:
          module: 'EXT-Pir',
          disabled: false,
            debug: false,
            gpio: 21,
            reverseValue: false
          module: 'EXT-Screen',
          position: 'top_left',
          disabled: false,
            debug: false,
            animateBody: true,
            delay: 60000,
            mode: 1,
            displayCounter: true,
            displayBar: true,
            displayAvailability: false,
            displayStyle: 'SemiCircle',
            displayLastPresence: true,
            lastPresenceTimeFormat: 'LL H:mm',
            detectorSleeping: false,
            gpio: 21,
            clearGpioValue: true,
            sound: false,
            touchMode: 3,
            ON: [],
            OFF: []
      I am using the MMM-PIR now using this config:
      module: 'MMM-Pir',
          debug: false,
          Display: {
            timeout: 1 * 60 * 1000,
            animate: true,
            style: 3,
            colorFrom: "#FF0000",
            colorTo: "#00FF00",
            mode: 1,
            counter: true,
            lastPresence: false,
            lastPresenceTimeFormat: "LL H:mm",
            availability: false,
            autoDimmer: false,
            xrandrForceRotation: "normal",
            wrandrForceRotation: "normal",
            wrandrForceMode: null,
            waylandDisplayName: "wayland-0"
          Pir: {
            mode: 1,
            gpio: 21
          Motion: {
            deviceId: 0,
            captureIntervalTime: 1000,
            scoreThreshold: 100
          Cron: {
            ON: [],
            OFF: []
          Touch: {
            mode: 3
          Governor: {
            sleeping: 4,
            working: 2
          Sounds: {
            on: "open.mp3",
            off: "close.mp3"
      I remember that there was a difference between TVservices and vcgencmd.
      I am using 64bit on a Pi3b.
      Any ideas?
      bugsounetB 1 Reply Last reply
      • bugsounetB
        bugsounet Banned @Che
        @Che The real question is now:
        What compositor do you use ? (X11, wayfire or labwc)
        I purpose to use X11 compositor. (it’s the better choice for rpi 3b+)
        Can you try this commands:
        sudo raspi-config nonint do_wayland W1
        sudo raspi-config nonint do_blanking 0
        and reboot your pi
        in your config of MMM-Pir, can you try mode 1 in Display block ?
        and if not work try mode 2 in Display block
        Tell me if better ?
        C 1 Reply Last reply
        • bugsounetB
          @Che
          Hi, just try to enable screen blancking with raspi-config tool
          • C
            Che @bugsounet
            @bugsounet said in MMM-Pir Monitor stays black instead of turning off completley:
            @Che
            Thanks. Tried that. Did not work. :-(
            The sensor is working because the countdown is visible and it´s reacting perfectly after detecting motion.
            The screen just dont turn off - it stays black which wasn´t an issue before updating.
            I´ve tried to
            DISPLAY=:0.0 xrandr --output HDMI-1 --off
            to see if I am able to turn it off manualy and via SSH. Output:
            warning: output HDMI-1 not found; ignoring
            Still a bit clueless how to fix that.
            Is there another option I could try? I know the monitor is able to be switched off as this was working before.
            • bugsounetB
              and reboot your pi
              Tell me if better ?
              • C
                Che @bugsounet
                and reboot your pi
                Tell me if better ?
                I´ve changed to X11 via raspi config and did the commands. Now it seems working. Thanks so far, buddy.
                BUT the Display rotated.
                I´ve tried to change it via sudo nano/boot/firmware/config.txt and add display_rotate=1
                Edit: Plugged in my USB mouse and changed it manually on the desktop.
                I think its working smoothly again.
                Merci bien, @bugsounet
                • bugsounetB
                  @Che
                  I am touched by your “thank you” in French!
                  Happy use,
                  @bugsounet
                  Reply Quote 1
