    MMM-Pir Monitor stays black instead of turning off completley
    6 Posts 2 Posters 549 Views 2 Watching
    • bugsounetB Offline
      bugsounet Banned @Che
      @Che
      Hi, just try to enable screen blancking with raspi-config tool
        Che @bugsounet
        @bugsounet said in MMM-Pir Monitor stays black instead of turning off completley:
        @Che
        Thanks. Tried that. Did not work. :-(
        The sensor is working because the countdown is visible and it´s reacting perfectly after detecting motion.
        The screen just dont turn off - it stays black which wasn´t an issue before updating.
        I´ve tried to
        DISPLAY=:0.0 xrandr --output HDMI-1 --off
        to see if I am able to turn it off manualy and via SSH. Output:
        warning: output HDMI-1 not found; ignoring
        Still a bit clueless how to fix that.
        Is there another option I could try? I know the monitor is able to be switched off as this was working before.
        bugsounetB 1 Reply Last reply Reply Quote 0
          @Che The real question is now:
          What compositor do you use ? (X11, wayfire or labwc)
          I purpose to use X11 compositor. (it’s the better choice for rpi 3b+)
          Can you try this commands:
          sudo raspi-config nonint do_wayland W1
          sudo raspi-config nonint do_blanking 0
          and reboot your pi
          in your config of MMM-Pir, can you try mode 1 in Display block ?
          and if not work try mode 2 in Display block
          Tell me if better ?
            Che @bugsounet
            and reboot your pi
            Tell me if better ?
            I´ve changed to X11 via raspi config and did the commands. Now it seems working. Thanks so far, buddy.
            BUT the Display rotated.
            I´ve tried to change it via sudo nano/boot/firmware/config.txt and add display_rotate=1
            Edit: Plugged in my USB mouse and changed it manually on the desktop.
            I think its working smoothly again.
            Merci bien, @bugsounet
              @Che
              I am touched by your “thank you” in French!
              Happy use,
              @bugsounet
