    Parsing error: Unexpected token {
    6 Posts 2 Posters 1.0k Views 2 Watching
      Dawcio232v2
      Error when loading magic mirror.
      dawcio232@raspberrypi:~/MagicMirror $ npm run start
      > magicmirror@2.29.0 start
      [2024-11-30 16:32:47.262] [LOG]   Starting MagicMirror: v2.29.0
      [2024-11-30 16:32:47.274] [LOG]   Loading config ...
      [2024-11-30 16:32:47.275] [LOG]   config template file not exists, no envsubst
      [2024-11-30 16:32:47.497] [INFO]  Checking config file /home/dawcio232/MagicMirror/config/config.js ...
      [2024-11-30 16:32:47.513] [ERROR] Your configuration file contains syntax errors :(
      Line 81 column 3: Parsing error: Unexpected token {
      Command line ^
      Config V
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "https://www.officeholidays.com/ics-all/poland"
      			module: "compliments",
      			position: "lower_third"
      			module: "weather",
      				weatherProvider: "openmeteo",
      				type: "current",
      				lat: 40.776676,
      				lon: -73.971321
                             module: 'MMM-ProfileSwitcher',
      		 	module: "weather",
      			header: "Codzienna",
      				type: "daily",
      				lat: 40.776676,
      				lon: -73.971321
                            module: 'MMM-Advent',
                            position: 'bottom_center', // This can be any of the regions, best results in center regions
                             module: "helloworld",
                             position: "bottom_bar", // This can be any of the regions.
                                      text: "Witaj Dawid!",
                             module: "MMM-MagicMover",
                                      updateInterval: 10 * 60 * 1000,
                                      ignoredRegions: [],
                                      maxMove: 15,
                                      moveWholescreen: false,
        sdetweil @Dawcio232v2
        @Dawcio232v2
        ---missing close brace for config: {----
          Dawcio232v2 @sdetweil
          @sdetweil it dosent work!
            @Dawcio232v2 can you run the config checker
            npm run config:check
            find the line it complains about, go back 1 and see if it is correct
            sometimes it is missing a trailing comma
            here is was a ,issing close brace }
              Dawcio232v2
                @Dawcio232v2 paste the text. Pictures don’t help
                Show the config, find line 82 and look for a missing trailing comma on line 81
