    issues updating MMM-calendar EXT3
    19 Posts 4 Posters 6.7k Views 4 Watching
    • J
      JMac
      I’ve had the notification that this module needs an update, the guidance says go into the module folder and run “git pull” when I run this I get an error of,
      your local changes to the following files would be overwritten by the merge: package-lock.json
      please commit them or stash them before you merge.
      Aborting.
      How do I mitigate for this issue without causing fundamental problems with my MM setup, It’s working perfectly at the moment and I don’t want to a knock down the first domino in chain of potential issues.
      Cheers.
        sdetweil @nschertz
        @nschertz git checkout
        restores it from the local source repo
        git reset
        removes it from the staged to be submitted as a change
        I posted the checkout first, then a user posted reset and I blindly followed it…
        my mistake
          sdetweil @JMac
          @JMac the package-lock.json was updated by the last npm install
          so do this, in the module folder
          git checkout package-lock.json
          then the
          npm install
          J 1 Reply Last reply
          • J
            JMac @sdetweil
            @sdetweil used both of those then tried to up date the rest of the module and still get the same issue when running git pull in the module folder, this is what it says;
            hint: Pulling without specifying how to reconcile divergent branches is
            hint: discouraged. You can squelch this message by running one of the following
            hint: commands sometime before your next pull:
            hint:
            hint: git config pull.rebase false # merge (the default strategy)
            hint: git config pull.rebase true # rebase
            hint: git config pull.ff only # fast-forward only
            hint:
            hint: You can replace “git config” with “git config --global” to set a default
            hint: preference for all repositories. You can also pass --rebase, --no-rebase,
            hint: or --ff-only on the command line to override the configured default per
            hint: invocation.
            Updating 3ca76d9…dfe2425
            error: Your local changes to the following files would be overwritten by merge:
            package-lock.json
            Please commit your changes or stash them before you merge.
            Aborting
              sdetweil @JMac
              @JMac said in issues updating MMM-calendar EXT3:
              sorry, brain fart…
              you need the git pull
              after the git reset , before the npm install
              • J
                JMac @sdetweil
                @sdetweil so just to be clear its,
                git reset
                git pull
                npm install
                within the calendar ext3 module folder?
                  sdetweil @JMac
                  @JMac no
                  edited
                  # put package-lock.json back to last git clone state
                  # update the module
                  git pull
                  # rerun npm install  with new code
                  npm install
                  all in the module folder
                  # lines are comments and will be ignored if you copy paste that whole thing
                  • N
                    nschertz
                    @sdetweil I just encountered the same problem and followed your instructions in your last post. This did not fix the problem. I continue to get the same error
                    “your local changes to the following files would be overwritten by the merge: package-lock.json
                    Aborting.”
                    Thoughts on what to do next?
                    Norb
                      sdetweil @nschertz
                      @nschertz you ARE in the module folder, right?
                      edited
                      cd ~/MagicMirror/modules/MMM-CalendarExt3
                      git pull
                      npm install
                      right?
                      BKeyportB N 2 Replies Last reply
                      • BKeyportB
                        just for information, the real issue is the the lock file is included in the package, right?
                          sdetweil @BKeyport
                          @BKeyport and it gets updated by npm install
                          You can do npm ci
                          Which will ONLY install the EXACT versions listed in the lock file, even if it’s wrong for your system
                          • N
                            nschertz @sdetweil
                            @sdetweil Correct. After executing “git reset package-lock.json”, I get the message “Unstaged changes after reset:
                            M package-lock.json”
                            I then run git pull and get
                            pi@MagicMirror:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
                            Updating e93534d…5f276d4
                            package-lock.json
                            Aborting
                              sdetweil @nschertz
                              @nschertz sorry, oops… wrong command!
                              fixed the prior posts with note edited
                              • N
                                nschertz
                                to clarify… execute “git checkout package.json” instead of " git reset package.json" or execute “git checkout package.json” and " git reset package.json"?
                                  sdetweil @nschertz
                                  git reset
                                  my mistake
                                  • N
                                    nschertz
                                    oops meant to type
                                    to clarify… execute “git checkout package-lock.json” instead of " git reset package-lock.json" or execute “git checkout package-lock.json” and " git reset package-lock.json"?
                                    • N
                                      nschertz
                                      Got it ! git checkout… worked! Thanks for the clarification on what git reset does verses git checkout.
                                      Reply Quote 1
                                        sdetweil @nschertz
                                        @nschertz awesome… sorry for the misdirection
                                          in the git model
                                          the files you see are called the working directory
                                          and the repo is hidden in the .git folder
                                          that is where the actual ‘state’/contents of each file exists
                                          so checkout copies the contents from the repo to the working directory
                                          if you were developing and had a change
                                          git status would show changed files in the working directory
                                          git diff will show WHAT changed on each file
                                          to lock it down in the local copy of the repo
                                          you git add it to a potential ‘commit’,
                                          then git status shows it as ‘staged’
                                          to REMOVE it from staged, use the git reset command
                                          git commit puts it into the local repo as a change
                                          then you ‘push’ your entire local repo to the parent (git remote -v)
                                          and the changes (if accepted) are merged and that change is in the master for
                                          all new ‘pulls’
                                          N 1 Reply Last reply
                                          • N
                                            nschertz @sdetweil
                                            @sdetweil thank you ! This explanation is very helpful. I’m still a little new to the git environment.
                                            Reply Quote 1
