    "npm run start" does not work. Returns "sh 1 ./node_modules/.bin/electron not found"
    14 Posts 2 Posters 3.1k Views 2 Watching
    • T Offline
      tony-72
      I appreciate all the hard work and assistance. So I believe it is working now. So I rebooted the Raspi and when it came up it showed there were updates. I allowed those updates to install. I then went into terminal and sudo update/sudo upgrade. After that, your script worked as advertised.
      Now I did not get through it all until this morning and have not been able to launch it again. I do know the pm2 works because it kept restarting MM every few seconds when I was trying to shut down the Raspi. I will mess with it tonight after i figure out how to disable the autostart. I believe it was “pm2 stop mm” or “pm2 stop MagicMirror”.
        sdetweil @tony-72
        @tony-72 pm2’s job is to keep the app running, so if it crashes pm2 restarts
        pm2 stop all
        pm2 logs --lines=50
        to look at the logs
        i strongly suggest stopping pm2 use while you install and test modules
        use npm start in the MagicMirror folder, ctrl-c to end, or ctrl-q on the browser
        this way you can see the messages from npm start easier
        • T Offline
          tony-72
          Awesome and thanks, everything working as advertised at the moment. About to attempt my first module install and config. Question, is there a text editor installed with your script? I was trying to figure out how to get VScode installed and where to install it, then realized there may be one on here already. What do you suggest, I have zero coding experience but I understand the concept and know a little from studying Cybersecurity.
            sdetweil @tony-72
            @tony-72 nano is the built in text editor, its text only
            vscode goes in system folders, has nothing to do with MM
            you could try my MMM-Config module which generates a form for config…
            https://github.com/sdetweil/MMM-Config
            also see this
            https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine
            see the first link in my sig below for installing modules… (I didn’t write it)
