    New install - (npm run install-mm) - returns errors
    6 Posts 2 Posters 1.6k Views 2 Watching
    • L Offline
      lostagain
      Hi, brand new user and no experience with Pi programming.
      Running Pi4 with 64bit new install. Pi all updated.
      Following instructions (have tried 6 times) all goes well until I enter the “npm run install-mm” and each time I get the following.
      leehill@raspberrypi:~/MagicMirror $ sudo npm run install-mm
      magicmirror@2.29.0 install-mm
      npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.29.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.29.0
      npm error notsup Required: {“node”:“>=20.9.0 <21 || 22”}
      npm error notsup Actual: {“npm”:“11.0.0”,“node”:“v23.4.0”}
      npm error A complete log of this run can be found in: /root/.npm/_logs/2024-12-18T19_34_41_408Z-debug-0.log
      what am I doing wrong?? Thanks!!
        sdetweil @lostagain
        @lostagain said in New install - (npm run install-mm) - returns errors:
        yes, we don’t support node 23 until next release, Jan 1.
        the 'easiest way back is
        sudo npm install n -g
        sudo n 22
        hash -r
        then start install again
        • L Offline
          lostagain @sdetweil
          @sdetweil said in New install - (npm run install-mm) - returns errors:
          Sam, you’re a genius!!! Thank you so much, been tearing my hair out with that!!
          • L lostagain has marked this topic as solved on
            sdetweil @lostagain
            @lostagain if you had used my installer script, it would have installed the correct version of node (listed as 1st alternative install choice)
            • L Offline
              lostagain @sdetweil
              @sdetweil Good to know (I’ll remember that next time!!) thank you
                sdetweil @lostagain
                @lostagain my upgrade script will do it too between releases
