    /usr/local/bin /node: cannot execute
    4 Posts 2 Posters 861 Views 2 Watching
    • C Offline
      crueschemeyer
      Hello,
      i am trying a fresh installation on a Raspberpi 5 32-bit Raspberry Pi OS (20241210)on NVME
      When using the script: githubcom/weil/MagicMirror_scripts the installation stops with "bash: line 273: /usr/local/bin/node: cannot execute: required file not found"l.
      ls -al /usr/local/bin
      total 114584
      drwxr-xr-x  2 root root      4096 Dec 22 16:12 .
      drwxr-xr-x 11 root root      4096 Dec 22 15:02 ..
      lrwxrwxrwx  1 root root        45 Dec 22 16:12 corepack -> ../lib/node_modules/corepack/dist/corepack.js
      lrwxrwxrwx  1 root root        27 Dec 22 15:02 n -> ../lib/node_modules/n/bin/n
      -rwxr-xr-x  1 root root 117318528 Dec 22 16:12 node
      lrwxrwxrwx  1 root root        38 Dec 22 16:12 npm -> ../lib/node_modules/npm/bin/npm-cli.js
      lrwxrwxrwx  1 root root        38 Dec 22 16:12 npx -> ../lib/node_modules/npm/bin/npx-cli.js
      A fresh-install on a Raspberry 3 works.
      What’s the problem?
        sdetweil @crueschemeyer
        @crueschemeyer did you install nodejs in advance of running my script?
        can you do
        node -v
          @crueschemeyer i have not tried 32bit on pi5, as pi5 is optimized for 64bit, and minimum 2 gig is more than enough memory
            @sdetweil i run my pi5 on 256 gig nvme using 64 bit os
