    MM on RPi3 is Extremely Slow
    4 Posts 2 Posters 764 Views 2 Watching
    • R
      raspberrypi9
      I am running MM on a RPi3B. I thought that it was freezing because after 10 minutes of running normally, the clock module will stop ticking and then the whole system becomes unresponsive. I tried ssh’ing into the box and after minutes, I got a prompt and was able to execute an ‘ls’ command, so I know the system is alive and just moving very slowly. The MM display still doesn’t update.
      I was wondering if anyone had tips on how to get MM running smoothly on a RPi3B? I don’t want to switch to a Pi4 or Pi5 because they don’t support changing the brightness (and the Pi3B does) and this is a critical feature for me.
      Thank you so much for your help.
        sdetweil @raspberrypi9
        @raspberrypi9 what os are you running?
        should be 32 bit legacy ibthink
        R 1 Reply Last reply
        • R
          raspberrypi9 @sdetweil
          @sdetweil I’ve tried it with Bullseye 32-bit and Bookworm 64-bit
            @raspberrypi9 do
            free -m
            this will tell you how much memory and swap space you have and are used.
            swap on sd cards is terrible
