    Query on MMM-CalendarExt3 modification
    14 Posts 3 Posters 2.0k Views 3 Watching
      sharkbait @sdetweil
      @sdetweil I added this entry to custom.css:
      html {
        cursor: default;
      For config.js, my settings for “MMM-CalendarExt3”, “MMM-pages” and “MMM-page-indicator” were as follows:
      		  module: "MMM-CalendarExt3",
      		  position: "bottom_bar",
      		  classes:"page3",
      		  title: "Our Family Calendar",
      			mode: "month",
      			headerWeekDayOptions: {
      				weekday: "narrow"
      			cellDateOptions: { day: 'numeric' }, // suppress month from appear in cellDate
      			monthIndex: 0, //0=curr_month, -1=prev, 1=next
      			maxEventLines: {0:6, 6:5},
      			firstDayOfWeek: 0,
      			calendarSet: [],
      			fontSize: '18px',
      			refreshInterval: 120000,
      		  disabled: false,
      			module: "MMM-page-indicator",
      			order: "*",
      			config: {},
      			disabled: false,
      			classes: "fixed"
      	// pages
      			module: "MMM-pages",
      			disabled: false,
      				  "page1"
      				  "page2"
      				  "page3"
      			  fixed: [
      				"fixed"
      			  animationTime: 10000, // time of fade in/out on page change
      			  rotationTime: 0,  // if you make this 0, then the pages only turn manually or via notification from somewhere else (indicator)
      			  hiddenPages: {
      			order: "*"
      A white circular dot at the bottom indicates whether the rendered page is page1 or page2 or page3. I tried tapping on the white dots but wasn’t able to switch among page views. Could it be a touchscreen (portrait orientation) xinput issue ?
        sharkbait @MMRIZE
        @MMRIZE I’ve removed the position of the “MMM-CustomInjection” module from the config.js as per your kind advice. The 3 buttons [prev], [current ] and [next] are still not appearing in the Calendar HeaderTitle (i.e. in my case -> DECEMBER 2024).
        This settings for my config.js are as follows:
        			mode: "month",
        			instanceId: "basicCalendar",
        			maxEventLines: {0:6, 6:5}, // Dynamically sized; 5 events for months with 6 weeks. 6 events for all others.
        			firstDayOfWeek: 0,
        			calendarSet: [],
        			fontSize: '18px',
        			module: "MMM-CustomInjection",
        The code deployed for the MMM-CustomInjection.js was:
        /* modules/MMM-CustomInjection/MMM-CustomInjection.js */
        Module.register("MMM-CustomInjection", {
          getStyles: function () {
            return [
              this.file("MMM-CustomInjection.css")
          notificationReceived: function (notification, payload, sender) {
            if (notification === "CX3_DOM_UPDATED") {
              const { instanceId } = payload
              this.inject(instanceId)
          inject: function (instanceId) {
            const moduleDom = document.querySelector(`#${instanceId}`)
            if (!moduleDom) return
            moduleDom.classList.add('custom-injected')
            const buttons = document.createElement('div')
            buttons.className = 'calendar-header-buttons'
            const prev = document.createElement('button')
            prev.className = 'calendar-header-button'
            prev.innerHTML = 'PREV'
            prev.onclick = () => {
              this.sendNotification('CX3_GET_CONFIG', {
                callback: (currentConfig) => {
                  this.sendNotification('CX3_SET_CONFIG', {
                    monthIndex: currentConfig.monthIndex - 1,
            const current = document.createElement('button')
            current.className = 'calendar-header-button'
            current.innerHTML = 'CURRENT'
            current.onclick = () => {
              this.sendNotification('CX3_RESET', {})
            const next = document.createElement('button')
            next.className = 'calendar-header-button'
            next.innerHTML = 'NEXT'
            next.onclick = () => {
                    monthIndex: currentConfig.monthIndex + 1,
            buttons.appendChild(prev)
            buttons.appendChild(current)
            buttons.appendChild(next)
            moduleDom.appendChild(buttons)
        The accompanying “MMM-CustomInjection.css” settings were:
        /* modules/MMM-CustomInjection/MMM-CustomInjection.css */
        .custom-injected {
          position: relative;
          .calendar-header-buttons {
            position: absolute;
            top: 30px;
            right: 0;
            display: flex;
            flex-direction: row;
            justify-content: space-between;
            gap: 10px;
            width: fit-content;
            .calendar-header-button {
              background-color: transparent;
              border: none;
              color: white;
              font-weight: bold;
          sdetweil @sharkbait
          @sharkbait said in Query on MMM-CalendarExt3 modification:
          I don’t know… but we can find out pretty easily , using the developers window…
          start mm
          using the keyboard on the MM screen, open the developers window, ctrl-shift-i
          (or use npm start dev to open from the commandline, don’t use pm2)
          select the elements tab and then click the arrow on top left
          then click one of the circles…
          that should open the document view with the buttons selected
          you can expand the sections to show the buttons (<a)
          now select the sources tab, expand modules in left nav, select MMM-PageIndicator, select MMM-PagIndicator.js, its source should appear in the right pane
          scroll down and click on the number on line 66, it should highlight, like this
          now click one of the page indicator buttons… mouse or finger
          it should show and stop on the line 66 instruction
          if it did then it is operating
          if it didn’t… hmm…
          if it stopped, click the line 66 again , and the highlight will be removed, and then push the blue arrow on the top right, to continue the application
          I will test on my touch screen laptop, no expectation that it will fail.
          mm is just a page in a browser… nothing special.(from an OS perspective)
          edit: tested on my laptop, worked with mouse and touch as expected
          edit: ctrl-shift-i to close the developer window
            MMRIZE @sharkbait
            @sharkbait
            Your CX3 may not be the latest version.(1.9.4)
