    Query on MMM-CalendarExt3 modification
    14 Posts 3 Posters 3.4k Views 3 Watching
      MMRIZE @sharkbait
      @sharkbait
      More polished version.
      MMM-CustomInjection
      /* modules/MMM-CustomInjection/MMM-CustomInjection.js */
      Module.register("MMM-CustomInjection", {
        getStyles: function () {
          return [
            this.file("MMM-CustomInjection.css")
        notificationReceived: function (notification, payload, sender) {
          if (notification === "CX3_DOM_UPDATED") {
            const { instanceId } = payload
            this.inject(instanceId)
        inject: function (instanceId) {
          const moduleDom = document.querySelector(`#${instanceId}`)
          if (!moduleDom) return
          moduleDom.classList.add('custom-injected')
          const buttons = document.createElement('div')
          buttons.className = 'calendar-header-buttons'
          const prev = document.createElement('button')
          prev.className = 'calendar-header-button'
          prev.innerHTML = 'PREV'
          prev.onclick = () => {
            this.sendNotification('CX3_GET_CONFIG', {
              callback: (currentConfig) => {
                this.sendNotification('CX3_SET_CONFIG', {
                  monthIndex: currentConfig.monthIndex - 1,
          const current = document.createElement('button')
          current.className = 'calendar-header-button'
          current.innerHTML = 'CURRENT'
          current.onclick = () => {
            this.sendNotification('CX3_RESET', {})
          const next = document.createElement('button')
          next.className = 'calendar-header-button'
          next.innerHTML = 'NEXT'
          next.onclick = () => {
                  monthIndex: currentConfig.monthIndex + 1,
          buttons.appendChild(prev)
          buttons.appendChild(current)
          buttons.appendChild(next)
          moduleDom.appendChild(buttons)
      /* modules/MMM-CustomInjection/MMM-CustomInjection.css */
      .custom-injected {
        position: relative;
        .calendar-header-buttons {
          position: absolute;
          top: 30px;
          right: 0;
          display: flex;
          flex-direction: row;
          justify-content: space-between;
          gap: 10px;
          width: fit-content;
          .calendar-header-button {
            background-color: transparent;
            border: none;
            color: white;
            font-weight: bold;
        sharkbait @sdetweil
        @sdetweil Thank you for taking the time to read my post and providing the guidance, and the additional modules I could try out. I have tried the 2 extensions as per your recommendation. The transition between pages is slick when set to auto rotate but for some reason, the page indicator module doesn’t allow me to switch (tap) between pages manually on my touchscreen, when I disable the auto-rotate .
          sharkbait @MMRIZE
          @MMRIZE Thank you for the taking the effort to provide me with the set of code. I’ve tested it and it works wonderfully.
            sharkbait @MMRIZE
            @MMRIZE I tried to implement this CustomInjection code but the rendered display turned out like this ![alt text]https://drive.google.com/file/d/1OUJ3EBz1CNMVqA9ds7kQhc4sTuovUoUA/view?usp=sharing.
            My setting in config.js is as follows:
            module: “MMM-CustomInjection”,
            position: “bottom_bar”,
            Instead of buttons, what I see is just the module name (MMM-CustomInjection, and below that module_5_MMM-CustomInjection).
            This is definitely a more polished solution, but I’m not sure why the display could not be rendered.
            M 1 Reply Last reply
              sdetweil @sharkbait
              @sharkbait
              and you set
                    rotationTime: 0,
              correct??
              it works for me…
              and u did change the cursor setting in css… right?
                MMRIZE @sharkbait
                @sharkbait
                MMM-CustomInjection doesn’t need to be positioned because that module works on background.
                /* config/config.js */
                	module: "MMM-CalendarExt3",
                	position: "bottom_bar",
                		mode: 'month',
                	module: "MMM-CustomInjection",
                  sharkbait @sdetweil
                  @sdetweil I added this entry to custom.css:
                  html {
                    cursor: default;
                  For config.js, my settings for “MMM-CalendarExt3”, “MMM-pages” and “MMM-page-indicator” were as follows:
                  		  classes:"page3",
                  		  title: "Our Family Calendar",
                  			mode: "month",
                  			headerWeekDayOptions: {
                  				weekday: "narrow"
                  			cellDateOptions: { day: 'numeric' }, // suppress month from appear in cellDate
                  			monthIndex: 0, //0=curr_month, -1=prev, 1=next
                  			maxEventLines: {0:6, 6:5},
                  			firstDayOfWeek: 0,
                  			calendarSet: [],
                  			fontSize: '18px',
                  			refreshInterval: 120000,
                  		  disabled: false,
                  			module: "MMM-page-indicator",
                  			order: "*",
                  			config: {},
                  			disabled: false,
                  			classes: "fixed"
                  	// pages
                  			module: "MMM-pages",
                  			disabled: false,
                  				  "page1"
                  				  "page2"
                  				  "page3"
                  			  fixed: [
                  				"fixed"
                  			  animationTime: 10000, // time of fade in/out on page change
                  			  rotationTime: 0,  // if you make this 0, then the pages only turn manually or via notification from somewhere else (indicator)
                  			  hiddenPages: {
                  			order: "*"
                  A white circular dot at the bottom indicates whether the rendered page is page1 or page2 or page3. I tried tapping on the white dots but wasn’t able to switch among page views. Could it be a touchscreen (portrait orientation) xinput issue ?
                    sharkbait @MMRIZE
                    @MMRIZE I’ve removed the position of the “MMM-CustomInjection” module from the config.js as per your kind advice. The 3 buttons [prev], [current ] and [next] are still not appearing in the Calendar HeaderTitle (i.e. in my case -> DECEMBER 2024).
                    This settings for my config.js are as follows:
                    			mode: "month",
                    			instanceId: "basicCalendar",
                    			maxEventLines: {0:6, 6:5}, // Dynamically sized; 5 events for months with 6 weeks. 6 events for all others.
                    			firstDayOfWeek: 0,
                    			calendarSet: [],
                    			fontSize: '18px',
                    The code deployed for the MMM-CustomInjection.js was:
                        return [
                    The accompanying “MMM-CustomInjection.css” settings were:
                    .custom-injected {
                      position: relative;
                        position: absolute;
                        top: 30px;
                        right: 0;
                        display: flex;
                        gap: 10px;
                        width: fit-content;
                          border: none;
                          color: white;
                          font-weight: bold;
                      sdetweil @sharkbait
                      @sharkbait said in Query on MMM-CalendarExt3 modification:
                      I don’t know… but we can find out pretty easily , using the developers window…
                      start mm
                      using the keyboard on the MM screen, open the developers window, ctrl-shift-i
                      (or use npm start dev to open from the commandline, don’t use pm2)
                      select the elements tab and then click the arrow on top left
                      then click one of the circles…
                      that should open the document view with the buttons selected
                      you can expand the sections to show the buttons (<a)
                      now select the sources tab, expand modules in left nav, select MMM-PageIndicator, select MMM-PagIndicator.js, its source should appear in the right pane
                      scroll down and click on the number on line 66, it should highlight, like this
                      now click one of the page indicator buttons… mouse or finger
                      it should show and stop on the line 66 instruction
                      if it did then it is operating
                      if it didn’t… hmm…
                      if it stopped, click the line 66 again , and the highlight will be removed, and then push the blue arrow on the top right, to continue the application
                      I will test on my touch screen laptop, no expectation that it will fail.
                      mm is just a page in a browser… nothing special.(from an OS perspective)
                      edit: tested on my laptop, worked with mouse and touch as expected
                      edit: ctrl-shift-i to close the developer window
                        MMRIZE @sharkbait
                        @sharkbait
                        Your CX3 may not be the latest version.(1.9.4)
