    "Invalid Date" appears in Weather module. MM v2.29.0
    25 Posts 5 Posters 8.2k Views 4 Watching
      sdetweil @VinGroot
      @VinGroot awesome
      • L Offline
        lif
        I have rebuilt my installation and used backup .js files.
        Everything has worked apart from the weather module.
        I am getting the ‘Invalid date’ message a temperature of NaN.
        I have tried adding the apiVersion: ‘2.5’
        weatherEndpoint: “/weather”
        Lines into the config.js file but then MagicMirror doesn’t load.
        the section of config.sys is:
        			module: "weather",
        				type: "current",
        				locationID: "2983291", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				apiKey: "cxxxxxxxxxxxx57f81f9d82849a2fc21a"
        			module: "weather",
        			header: "Weather Forecast",
        				type: "forecast",
        				apiKey: "cxxxxxxx57f81f9d82849a2fc21a"
          sdetweil @lif
          @lif are you on 2.29 or 2.30?
          cd ~/MagicMirror
          grep version package. json
          see https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
            sdetweil @lif
            @lif said in "Invalid Date" appears in Weather module. MM v2.29.0:
            > I have tried adding the apiVersion: '2.5'
            > weatherEndpoint: "/weather"
            each of those lines had trailing commas, right?
            • L Offline
              lif @sdetweil
              @sdetweil said in "Invalid Date" appears in Weather module. MM v2.29.0:
              Not that line but that wasn’t the problem :-)
              Thanks for the link showing how to subscribe to OpenWeathermap which solved the problem.
