    MMM-CalendarExt3 and EventTransformer not transformering....
    6 Posts 2 Posters 923 Views 2 Watching
      justme2024
      Hello and thanks in advance to anyone who can help as I am at the end of my rope on this.
      I am a simple man, and i want to change the text in the google calendar i am pulling from to Blue for certain events based on the title.
      The calendar however only defaults to the usual white text.
      I have previously attempted to use the transform function with a custom css however that did not work either. I used the ctrl-shift-I to inspect the items, which…well showed they were white so maybe i didnt understand what to look for.
      Here is a view of my config file - any help would be much appreciated
       module: "MMM-CalendarExt3",
       position: "bottom_bar",
      	eventTransformer: (ev) => {
        if (ev.title.search('Owen') > -1) ev.color = 'blue'
        return ev
        justme2024 @sdetweil
        Thanks so much - this documentation fell a little bit flat - it was only changing the symbol and not the font itself… however… at this link https://forum.magicmirror.builders/topic/18528/calendar-calendarext3-font-color-and-symbol/12?page=2 it outlined a font change option
        now, im not great at all of this (clearly) however after some well thought out trial and error i was able to get this code to adjust for the font change, appreciate the help!!
        Hopefully they add some updates to the documentation
          ev.title=ev.title.replace ('Owen','<font color=blue>Owen</font>')
        return ev
        apologies for the formatting
          sdetweil @justme2024
          @justme2024
          that transformer has to be in the module config:{} section
          everything outside the config section belongs to MagicMirror, inside belongs to the module
          https://docs.magicmirror.builders/modules/configuration.html#animated
            @sdetweil Thanks - this worked for the icon itself - Is there documentation for the eventtransformer? looking to change the text not so much the icon, but assumptions such as using color-text: ‘blue’ hasnt worked
            i will say the example in the module around eventtransformer should likely be updated to include the config needs, although i appreciate the link to better understand when its needed
              @justme2024 not my module but the doc lists the event fields
                return ev
                  @justme2024 Documentation cannot cover every idea. (people don’t read them now anyhow, me included)
