    Help with upgrading to 2.30.0
    6 Posts 2 Posters 2.5k Views 3 Watching
      siujd2001
      My MM worked fine under 2.29.0. I had to run some updates recently to MMM-CalendarExt3 and MMM-Pir, and noticed that there was a new version - 2.30.0. I tried to run the sdetweil upgrade script, but things totally went sideways. At first, MMM-CalendarExt3 wouldn’t pull events from Google Calendar, and MMM-Pir would show up as undefined. Then things got worse - now MM won’t even run at all.
      Please help.
      Below is the output from my current state of trying to run the sdetweil scripts:
      Running test script:
      @raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
      update log will be in /home//MagicMirror/installers/upgrade.log
      doing test run = true, NO updates will be applied!
      Check current Node installation …
      Node currently installed. Checking version number.
      Minimum Node version: v20.18.1
      Installed Node version: V1.0.0
      Node should be upgraded.
      Node.js upgrade defered, doing test run
      Check current NPM installation …
      NPM currently installed. Checking version number.
      Minimum npm version: V10.8.2
      Installed npm version: V10.8.2
      No npm upgrade necessary.
      saving custom.css
      reverting to master branch from (HEAD, saving changed files
      Previous HEAD position was 94c3c699 Release 2.29.0 (#3568)
      Switched to branch ‘master’
      upgrading from version 2.30.0 to 2.30.0
      fetching latest revisions
      cp: cannot stat ‘installers/mm.sh’: No such file or directory
      Checking for modules with removed libraries
      bash: line 937: /usr/local/bin/node: No such file or directory
      no modules found needing npm refresh
      restoring custom.css
      Running update script:
      @raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
      doing test run = false
      installing correct version of node and npm, please wait
      /usr/local/bin/n: line 746: /usr/local/bin/node: No such file or directory
      Installing Node.js …
      apply: line 318: [: too many arguments
      tar (child): /home//node_release-.tar.gz: Cannot open: No such file or directory
      tar (child): Error is not recoverable: exiting now
      tar: Child returned status 2
      tar: Error is not recoverable: exiting now
      node version is apply: line 353: /usr/local/bin/node: No such file or directory
      apply: line 355: /usr/local/bin/node: No such file or directory
      Node.js installation Done! version=
      apply: line 361: [: too many arguments
      saving custom.css
      local version 2.30.0 already same as master 2.30.0
      Trying to run MagicMirror
      @raspberrypi:~/MagicMirror $ npm run start
      magicmirror@2.30.0 start
      npm run start:x11
      magicmirror@2.30.0 start:x11
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [2025-01-03 02:01:30.545] [ERROR] App threw an error during load
      [2025-01-03 02:01:30.549] [ERROR] Error: Cannot find module ‘undici’
      Require stack:
      • /home//MagicMirror/js/app.js
      • /home//MagicMirror/js/electron.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
        at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
        at Module._resolveFilename (/home//MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:1058:27)
        at c._load (node:electron/js2c/node_init:2:17025)
        at Module.require (node:internal/modules/cjs/loader:1318:19)
        at require (node:internal/modules/helpers:179:18)
        at Object. (/home//MagicMirror/js/app.js:15:40)
        at Module._compile (node:internal/modules/cjs/loader:1484:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
        at Module.load (node:internal/modules/cjs/loader:1295:32)
        at Module._load (node:internal/modules/cjs/loader:1111:12)
        at Object. (/home//MagicMirror/js/electron.js:4:14)
        A JavaScript error occurred in the main process
        Uncaught Exception:
        Require stack:
        ^C/home//MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      Trying full installation:
      @raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
      $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
      $$$$$$ $$ | _
      $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
      $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
      $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
      _
      | _
      | _
      | _
      $$ |_| _
      |_| _|_|_| __| _
      / _| _______|
      _
      ____/
      install log being saved to /home//install.log
      Updating packages …
      Installing helper tools …
      bash: line 287: /usr/local/bin/node: No such file or directory
      node failed to execute, please check the error message and resolve before trying again
        sdetweil @siujd2001
        @siujd2001 let me look at that
        looks like you had pulled the develop branch on 2.29
        S S 2 Replies Last reply Reply Quote 0
          siujd2001 @sdetweil
          @sdetweil After everything was borked, I did try to run 2.29.0 and everything went back to “normal” except MMM-Pir, which remained as “undefined”.
          Currently nothing works at all.
            @siujd2001 can you post the ~/MagicMirror/installers/upgrade.log it has more info
            it may be big, so email to me at my same userid at gmail.com
            it has no personal info in it
              @siujd2001 yes, node is messed up, and then you can’t npm install cause node is messed up, but the code was changed… so you are half installed…
              I need the log to see more detail, so I can advise how to fix it
                sdetweil
                @mvrlogins yes, doing test run.
                because your (all of you) MagicMirror systems have been built and are important to you, i am very cautious about making changes.
                we update MagicMirror 4 times a year, i dont need to crash your system every time!!
                so upgrade is a 2 part process
                also, many users, not yet knowing the system design, change MagicMirror files which should not and do not need to be modified. but IF modified, the update will fail unless forced AND your changes (which you may not remember) will be lost
                1st is test, make no changes
                if all goes well
                2nd pass, actually DO the upgrade, same command, with an additional parameter , apply
                there is a second copy/paste line in the doc for this
                you only did pass 1, test mode
