    slideshow issue from NAS
    13 Posts 2 Posters 6.5k Views 2 Watching
    • P
      palp
      Hello Experts,
      need your help and guidance please -
      I’ve started using MM recently on pi 02w (dietpi) and it has been working good with module MMM-BackgroundSlideshow to cast slideshow from a network drive (mounted via samba) i.e.
      “imagePaths: [‘/mnt/samba/myPicFrame/’],”
      However after i upgraded to MM 2.30.0 yesterday slideshow is being stopped and a black screen with no other module data is being displayed.
      But when i switch back to MMM-BackgroundSlideshow local pic directory i.e.
      “imagePaths: [‘modules/MMM-BackgroundSlideshow/exampleImages/’],”
      its working fine - only for the network mount drive screen is going blank.
      Please suggest any remedy or anything im doing incorrect.
      Thanks, Pratap
        sdetweil @palp
        @palp did you reboot? is the link mounted?
        ls /mnt/samba/myPicFrame/
        should return the list of pics
        if not
        sudo mount -a
        if the mount is defined in /etc/fstab
        • P
          palp
          Thanks Sam, for quick response.
          yes i’ve added the mount on boot in the fstab and i can browse the pictures in the /mnt/samba/myPicFrame. in fact MM is starting with those picture but going blank in a while (approx 10-15 min after start may be).
          Thans, Pratap
          • P
            palp @sdetweil
            @sdetweil yes link is mounted correctly i can see the picture files in ‘ls /mnt/samba/myPicFrame/’ - infact MM is starting with those picture correctly but after a while (may be 10-15 min) screen is going blank.
            so i guess mount of the network share is correct but something else blanking the screen after a while.
            thanks for your response. please help further.
            Thanks, Pratap
              sdetweil @palp
              @palp the module produces logging to where npm start is done
              if using pm2, then
              pm2 logs --lines=xxxx
              xxxx most recent line count, default 15
                @palp also if you have a mouse or keyboard…
                does that wake it up?
                and then the developers console (if the browser is still alive)
                ctrl-shift-i
                select the console tab
                • P
                  palp @sdetweil
                  @sdetweil thanks again.
                  ref attached image for the log line - it is reading the networkshare/*.jpg and showing something ‘stream closed’ not sure if that is an issue or not
                  then i attached a keyboard and black screen does not wake by keystroke, however mouse pointer moves on black screen.
                  also ctrl+shift+i does nothing however ctrl+m is minimizing the MM window and showing desktop.
                    sdetweil @palp
                    @palp ok, the browser side died. does the log show the same image file at crash?
                    • P
                      palp @sdetweil
                      @sdetweil yes, i see the same lines in the .pm2/log/mm-out.log
                      not sure if im reading correct log file though!
                        sdetweil @palp
                        @palp just for grins can you move butterfly.jpg out of the samba server folder
                          sdetweil @palp
                          @palp i had a case like that a few years ago. one of the images was misformatted (actually 3 of 6,000)
                          i edited it and saved it again and it was ok after that
                          • P
                            palp @sdetweil
                            @sdetweil yes you are right - i’ve removed all 50+ jpg files and started with couple of them and looks like its working i mean screen is not going blank even after longer time - as expected.
                            now i need to find which jpg file(s) is bad and causing this and put them back.
                            anyway thanks for your help!
                            • P palp has marked this topic as solved on
                              sdetweil @palp
                              @palp the error message tells you which jpg…
                              may have to cycle thru them on screen…
