    Calendar moves right by 5 px every update
    26 Posts 2 Posters 13.5k Views 2 Watching
    • E Offline
      emwtur
      Since updating to latest MagicMirror my calendar has started shifting right continously
      have not changed anything in configuration since updating
      portion of config.js
                  header: "Min Kalender",
                  showLocation: true,
                  maximumEntries: 12,
                  maximumNumberOfDays: 40,
                  wrapEvents: true,
                      colored: true,
                      fade: false,
                      showLocation: false,
                      wrapEvents: false,
                      calendars: [{
      all calendars are reading from local .ics files read from other scripts
      (“webcal://127.0.0.1:8080/config/xxx.ics”)
      in html is looks like a
      <span class="fas fa-fw fa-" style="padding-left: 5px;"></span>
      is inserted for each update - I have some 25 of them now - there are a few less if I restart mm
      /Per-Eric
        sdetweil @emwtur
        @emwtur can you show any custom.css you might have
        also please use code block around config or log entries
        paste into editor
        select pasted text hit the </> button above the editor
          sdetweil @emwtur
          @emwtur do you have a custom symbol defined for the calendar urls?
          • E Offline
            emwtur @sdetweil
            @sdetweil Yes I did - but I have tried without
            Checked the code and it led me to checking symbol settings - tried disabling all kinds of symbols -
            sample cal
                                symbol: "google",
                                color: "#00F0F0",
                                maximumEntries: 4,
                                url: "webcal://127.0.0.1:8080/config/emwtur-gmail.ics",
              sdetweil @emwtur
              @emwtur but did u install custom symbols before?
              the html seems like it is missing the symbol name
              • E Offline
                emwtur
                no custom css’s anywhere…
                Only thing, when I come to think of it - is that I have an old version of another calendar module …
                I’ll uninstall that to check that it’s not causing any problems
                  sdetweil @emwtur
                  @emwtur there is only one custom.css
                  css/custom.css where all style overrides go
                  • E Offline
                    emwtur @sdetweil
                    Sorry if I’m not used to this forum messaging.
                    I have installed MM new - latest and greatest - after new year using the scripts at https://github.com/sdetweil/MagicMirror_scripts
                    your’s I believe :-)
                    I have not modified anything inside MM - only added a few modules - the same I had with my previos version - which was the penultimate release I think.
                    I have not touched any css files - god forbid - I am a backend dev cheating a little in react.js at work css always end up with !important and strange stuff
                      sdetweil @emwtur
                      @emwtur is that cal entry the one with the html?
                      • E Offline
                        emwtur @sdetweil
                        @sdetweil No it was another calendar module showing a week view -
                        I was showing the html I get when I browse to the url of the machine showing the magic mirror - should be the same html that is shown on the mirror - I have the same problems in both anyway
                        I have removed the other calendar module and still have the problem
                        /P
                          sdetweil @emwtur
                          @emwtur still, the symbol name is not being used
                          • E Offline
                            emwtur @sdetweil
                            Doing the dirty fix :
                            round line 320 in calendars.js :
                                                        const symbols = this.symbolsForEvent(event);
                                                        symbols.forEach((s, index) => {
                            // const symbol = document.createElement(“span”);
                            // symbol.className = s;
                            // if (index > 0) {
                            // symbol.style.paddingLeft = “5px”;
                            // symbolWrapper.appendChild(symbol);
                            eventWrapper.appendChild(symbolWrapper);
                            removes the issue for me - I assume the calculation goes wrong somehow - I tried to remove my different calendars one by one and it did not affect the “move right” so
                            For today - I’ll leave it at that - can’t tell if it’s parsing the calendar and thinking there are more and more symbols ?
                              sdetweil @emwtur
                              @emwtur can you show the calendar configs? xxx out the urls
                              there was a fix in the area…
                              • E Offline
                                emwtur @sdetweil
                                I’ll reinstall some stuff and try to remove all calendars I had and only use the one from the sample config and see how that goes.
                                Should point to something being wrong with my .ics files ( or how they are parsed, if it works
                                /P
                                  sdetweil @emwtur
                                  @emwtur the fix was when there were multiple symbols
                                  symbol:[x,y,z]
                                  in the calendar specification
                                  E 2 Replies Last reply Reply Quote 0
                                  • E Offline
                                    emwtur @sdetweil
                                    Yes I had multiple but tried to remove all of them - didn’t help.
                                    Anyway having ONLY the cal from config.js.sample looks to work - having restored calendar.js to original
                                    • E Offline
                                      emwtur @sdetweil
                                      it has to do with multiple symbols.
                                      looks like the bug can be reproduced using the cal setting from the sample file , just add another symbol and watch it move
                                      		header: "US Holidays",
                                      					symbol: ["calendar-check","google"]
                                      					url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                                        sdetweil @emwtur
                                        @emwtur great!!! thsnks
                                        • E Offline
                                          emwtur @sdetweil
                                          Having single symbols is something I can live with - was just confused - it worked before updating…
                                          thank YOU for great work with Magic Mirror.
                                          regards
                                          /Per-Eric
                                            sdetweil @emwtur
                                            @emwtur ok, i made the change , so gotta figure out how i screwed that up
