Calendar moves right by 5 px every update
26 Posts 2 Posters 8.6k Views 2 Watching
  • E Offline
    emwtur
    Since updating to latest MagicMirror my calendar has started shifting right continously
    have not changed anything in configuration since updating
    portion of config.js
                header: "Min Kalender",
                showLocation: true,
                maximumEntries: 12,
                maximumNumberOfDays: 40,
                wrapEvents: true,
                    colored: true,
                    fade: false,
                    showLocation: false,
                    wrapEvents: false,
                    calendars: [{
    all calendars are reading from local .ics files read from other scripts
    (“webcal://127.0.0.1:8080/config/xxx.ics”)
    in html is looks like a
    <span class="fas fa-fw fa-" style="padding-left: 5px;"></span>
    is inserted for each update - I have some 25 of them now - there are a few less if I restart mm
    /Per-Eric
    S 2 Replies Last reply Jan 3, 2025, 7:11 PM Reply Quote 0
    • S Away
      sdetweil @emwtur
      @emwtur can you show any custom.css you might have
      also please use code block around config or log entries
      paste into editor
      select pasted text hit the </> button above the editor
      • S Away
        sdetweil @emwtur
        @emwtur do you have a custom symbol defined for the calendar urls?
        E 1 Reply Last reply Jan 3, 2025, 7:41 PM Reply Quote 0
        • E Offline
          emwtur @sdetweil
          @sdetweil Yes I did - but I have tried without
          Checked the code and it led me to checking symbol settings - tried disabling all kinds of symbols -
          sample cal
                              symbol: "google",
                              color: "#00F0F0",
                              maximumEntries: 4,
                              url: "webcal://127.0.0.1:8080/config/emwtur-gmail.ics",
          S 1 Reply Last reply Jan 3, 2025, 7:43 PM Reply Quote 0
          • S Away
            sdetweil @emwtur
            @emwtur but did u install custom symbols before?
            the html seems like it is missing the symbol name
            • E Offline
              emwtur
              no custom css’s anywhere…
              Only thing, when I come to think of it - is that I have an old version of another calendar module …
              I’ll uninstall that to check that it’s not causing any problems
              S 1 Reply Last reply Jan 3, 2025, 7:47 PM Reply Quote 0
              • S Away
                sdetweil @emwtur
                @emwtur there is only one custom.css
                css/custom.css where all style overrides go
                E 1 Reply Last reply Jan 3, 2025, 8:11 PM Reply Quote 0
                • E Offline
                  emwtur @sdetweil
                  Sorry if I’m not used to this forum messaging.
                  I have installed MM new - latest and greatest - after new year using the scripts at https://github.com/sdetweil/MagicMirror_scripts
                  your’s I believe :-)
                  I have not modified anything inside MM - only added a few modules - the same I had with my previos version - which was the penultimate release I think.
                  I have not touched any css files - god forbid - I am a backend dev cheating a little in react.js at work css always end up with !important and strange stuff
                  S 1 Reply Last reply Jan 3, 2025, 8:21 PM Reply Quote 0
                  • S Away
                    sdetweil @emwtur
                    @emwtur is that cal entry the one with the html?
                    E 1 Reply Last reply Jan 3, 2025, 8:25 PM Reply Quote 0
                    • E Offline
                      emwtur @sdetweil
                      @sdetweil No it was another calendar module showing a week view -
                      I was showing the html I get when I browse to the url of the machine showing the magic mirror - should be the same html that is shown on the mirror - I have the same problems in both anyway
                      I have removed the other calendar module and still have the problem
                      /P
                      S 1 Reply Last reply Jan 3, 2025, 8:33 PM Reply Quote 0
                      1 / 3
