    Calendar moves right by 5 px every update
    26 Posts 2 Posters 21.2k Views 2 Watching
    • E
      emwtur @sdetweil
      Sorry if I’m not used to this forum messaging.
      I have installed MM new - latest and greatest - after new year using the scripts at https://github.com/sdetweil/MagicMirror_scripts
      your’s I believe :-)
      I have not modified anything inside MM - only added a few modules - the same I had with my previos version - which was the penultimate release I think.
      I have not touched any css files - god forbid - I am a backend dev cheating a little in react.js at work css always end up with !important and strange stuff
        sdetweil @emwtur
        @emwtur is that cal entry the one with the html?
        • E
          emwtur @sdetweil
          @sdetweil No it was another calendar module showing a week view -
          I was showing the html I get when I browse to the url of the machine showing the magic mirror - should be the same html that is shown on the mirror - I have the same problems in both anyway
          I have removed the other calendar module and still have the problem
          /P
            sdetweil @emwtur
            @emwtur still, the symbol name is not being used
            • E
              emwtur @sdetweil
              Doing the dirty fix :
              round line 320 in calendars.js :
                                          const symbols = this.symbolsForEvent(event);
                                          symbols.forEach((s, index) => {
              // const symbol = document.createElement(“span”);
              // symbol.className = s;
              // if (index > 0) {
              // symbol.style.paddingLeft = “5px”;
              // symbolWrapper.appendChild(symbol);
              eventWrapper.appendChild(symbolWrapper);
              removes the issue for me - I assume the calculation goes wrong somehow - I tried to remove my different calendars one by one and it did not affect the “move right” so
              For today - I’ll leave it at that - can’t tell if it’s parsing the calendar and thinking there are more and more symbols ?
                sdetweil @emwtur
                @emwtur can you show the calendar configs? xxx out the urls
                there was a fix in the area…
                • E
                  emwtur @sdetweil
                  I’ll reinstall some stuff and try to remove all calendars I had and only use the one from the sample config and see how that goes.
                  Should point to something being wrong with my .ics files ( or how they are parsed, if it works
                  /P
                    sdetweil @emwtur
                    @emwtur the fix was when there were multiple symbols
                    symbol:[x,y,z]
                    in the calendar specification
                    E 2 Replies Last reply Reply Quote 0
                    • E
                      emwtur @sdetweil
                      Yes I had multiple but tried to remove all of them - didn’t help.
                      Anyway having ONLY the cal from config.js.sample looks to work - having restored calendar.js to original
                      • E
                        emwtur @sdetweil
                        it has to do with multiple symbols.
                        looks like the bug can be reproduced using the cal setting from the sample file , just add another symbol and watch it move
                        		header: "US Holidays",
                        					symbol: ["calendar-check","google"]
                        					url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                          sdetweil @emwtur
                          @emwtur great!!! thsnks
                          • E
                            emwtur @sdetweil
                            Having single symbols is something I can live with - was just confused - it worked before updating…
                            thank YOU for great work with Magic Mirror.
                            regards
                            /Per-Eric
                              sdetweil @emwtur
                              @emwtur ok, i made the change , so gotta figure out how i screwed that up
                                @emwtur want to try the fix
                                calendar.js , line 915
                                			if (p instanceof Array) {   // keep add brace, remove rest of line or // comment out
                                			 let temp=[]
                                			 p.forEach(name=>{temp.push(className +name)});
                                			 p = temp
                                			else p = className + p;  // keep
                                • E
                                  emwtur @sdetweil
                                  Looks like it’s working with that fix - line numbers didn’t match so I had to think a little before applying - tested with multiple symbols on some cals and both symbols show and stay in place
                                  /Per-Eric
                                    sdetweil @emwtur
                                    @emwtur awesome!!!
                                      sdetweil @emwtur
                                      @emwtur the fix for this has been accepted and added to the next release (develop branch)
                                      develop includes the fix for broadcast clipping too…
                                      if you have the develop branch, then you can git pull to update
                                      if you don’t have develop, then see this topic
                                      https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                      • E
                                        emwtur @sdetweil
                                        I’m happy sitting with modded code - I’ll have to stash it when next release comes in march or start fresh again.
                                        Thanks for your efforts once again !
                                        /Per-Eric
                                          sdetweil @emwtur
                                          @emwtur my upgrade script will handle that
                                          it will say that the calendar.js is modified, do you want to save that,
                                          say no…
                                          if you run the test version first, it wont change anything, but still will warn you
                                          (how to remember if you changed files…)
