    Calendar moves right by 5 px every update
    26 Posts 2 Posters 20.4k Views 2 Watching
      @emwtur want to try the fix
      calendar.js , line 915
      			if (p instanceof Array) {   // keep add brace, remove rest of line or // comment out
      			 let temp=[]
      			 p.forEach(name=>{temp.push(className +name)});
      			 p = temp
      			else p = className + p;  // keep
      • E Offline
        emwtur @sdetweil
        Looks like it’s working with that fix - line numbers didn’t match so I had to think a little before applying - tested with multiple symbols on some cals and both symbols show and stay in place
        /Per-Eric
          sdetweil @emwtur
          @emwtur awesome!!!
            sdetweil @emwtur
            @emwtur the fix for this has been accepted and added to the next release (develop branch)
            develop includes the fix for broadcast clipping too…
            if you have the develop branch, then you can git pull to update
            if you don’t have develop, then see this topic
            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
            • E Offline
              emwtur @sdetweil
              I’m happy sitting with modded code - I’ll have to stash it when next release comes in march or start fresh again.
              Thanks for your efforts once again !
              /Per-Eric
                sdetweil @emwtur
                @emwtur my upgrade script will handle that
                it will say that the calendar.js is modified, do you want to save that,
                say no…
                if you run the test version first, it wont change anything, but still will warn you
                (how to remember if you changed files…)
