    Calendar moves right by 5 px every update
    26 Posts 2 Posters 12.5k Views 2 Watching
      sdetweil @emwtur
      @emwtur but did u install custom symbols before?
      the html seems like it is missing the symbol name
      • E Offline
        emwtur
        no custom css’s anywhere…
        Only thing, when I come to think of it - is that I have an old version of another calendar module …
        I’ll uninstall that to check that it’s not causing any problems
          sdetweil @emwtur
          @emwtur there is only one custom.css
          css/custom.css where all style overrides go
          • E Offline
            emwtur @sdetweil
            Sorry if I’m not used to this forum messaging.
            I have installed MM new - latest and greatest - after new year using the scripts at https://github.com/sdetweil/MagicMirror_scripts
            your’s I believe :-)
            I have not modified anything inside MM - only added a few modules - the same I had with my previos version - which was the penultimate release I think.
            I have not touched any css files - god forbid - I am a backend dev cheating a little in react.js at work css always end up with !important and strange stuff
              sdetweil @emwtur
              @emwtur is that cal entry the one with the html?
              • E Offline
                emwtur @sdetweil
                @sdetweil No it was another calendar module showing a week view -
                I was showing the html I get when I browse to the url of the machine showing the magic mirror - should be the same html that is shown on the mirror - I have the same problems in both anyway
                I have removed the other calendar module and still have the problem
                /P
                  sdetweil @emwtur
                  @emwtur still, the symbol name is not being used
                  • E Offline
                    emwtur @sdetweil
                    Doing the dirty fix :
                    round line 320 in calendars.js :
                                                const symbols = this.symbolsForEvent(event);
                                                symbols.forEach((s, index) => {
                    // const symbol = document.createElement(“span”);
                    // symbol.className = s;
                    // if (index > 0) {
                    // symbol.style.paddingLeft = “5px”;
                    // symbolWrapper.appendChild(symbol);
                    eventWrapper.appendChild(symbolWrapper);
                    removes the issue for me - I assume the calculation goes wrong somehow - I tried to remove my different calendars one by one and it did not affect the “move right” so
                    For today - I’ll leave it at that - can’t tell if it’s parsing the calendar and thinking there are more and more symbols ?
                      sdetweil @emwtur
                      @emwtur can you show the calendar configs? xxx out the urls
                      there was a fix in the area…
                      • E Offline
                        emwtur @sdetweil
                        I’ll reinstall some stuff and try to remove all calendars I had and only use the one from the sample config and see how that goes.
                        Should point to something being wrong with my .ics files ( or how they are parsed, if it works
                        /P
                        • 3 / 3
