    Problem with SolarEdgeLite module... please help...
    4 Posts 2 Posters 1.1k Views 2 Watching
    • O Offline
      osnapus
      Hello everyone, I have problem, after installation the newest version of MagicMirror.
      Raspberry Pi 4, fresh sd card, apt update, apt upgrade, and after start magic mirror, nothing happen, and log from pm2 logs show this on red…
      [2025-01-05 08:44:57.000] [ERROR] (node:4175) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-SolarEdgeLite/node_helper.js
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/js/electron.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
        at s._resolveFilename (node:electron/js2c/browser_init:2:120689)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:1058:27)
        at c._load (node:electron/js2c/node_init:2:16955)
        at Module.require (node:internal/modules/cjs/loader:1318:19)
        at require (node:internal/modules/helpers:179:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-SolarEdgeLite/node_helper.js:1:17)
        at Module._compile (node:internal/modules/cjs/loader:1484:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
        at Module.load (node:internal/modules/cjs/loader:1295:32)
        at Module._load (node:internal/modules/cjs/loader:1111:12)
        at loadModule (/home/pi/MagicMirror/js/app.js:200:19)
      Can anyone help?
      Thank You so much
      Piotr
      • O Offline
        osnapus
        Thank You for response.
        This is how i resolve problem with this module (with help of my brother Wojtek :D)
        (list of commands)
        curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.3/install.sh | bash
        export NVM_DIR=“$HOME/.nvm”
        [ -s “$NVM_DIR/nvm.sh” ] && . “$NVM_DIR/nvm.sh”
        [ -s “$NVM_DIR/bash_completion” ] && . “$NVM_DIR/bash_completion”
        nvm install 22.9.0
        nvm use 22.9.0
        inside MagicMirror folder:
        rm -rf node_modules
        rm -rf package-lock.json
        npm install
        npm install request --save
        npm start
        After this MMM-SolarEdge works perfect
        Piotr
          sdetweil @osnapus
          @osnapus see
          • O Offline
            osnapus
            (list of commands)
            nvm install 22.9.0
            nvm use 22.9.0
            rm -rf node_modules
            npm install
            npm start
            Piotr
              sdetweil @osnapus
              @osnapus cool, but be ready
              because you added request at the MagicMirror folder you have modified the package.json and package-lock.json which will block the next upgrade for MagicMirror
              you will have to discard those changes to do the MagicMirror upgrade, but then Solaredge wont work again
              you should
              npm install request
              in the Solaredge module folder
              if you use my upgrade script it will ask if you want to keep these changes (no)
              but it will fix Solaredge for you
              you could run the upgrade script now with force as a parameter instead off apply to cleanup now
              next MagicMirror version release is April 1
