    Cant display Apple Calendar
    3 Posts 2 Posters 689 Views 2 Watching
    • T Offline
      tejaso
      I am trying to use vdirsyncer to display a shared family calendar.
      I have successfully configured and have a valid ICS file.
      When I try to insert the calendar file into the configuration as described, I get an error that the calendar module has an error and to check the logs.
      When I check the logs, I see
      Calendar Error. Could not fetch calendar:
      Error: Not Found
      The file exists in the default location /MagicMirror/Modules/calendars/calendarname.ics
      My config looks like this:
      url: “http://localhost:8080/modules/calendars/calendarname.ics”
      webdav and file equiv’s have been tried in the configuration to no avail.
      Entering localhost:8080 gets the MM display page.
      Im thinking its a web issue. File exists, permissions are set to anyone for view all the way to the ICS file.
      Anyone have ideas?
        sdetweil @tejaso
        @tejaso did you make the calendars folder ??
        as it doesn’t exist by default
          sdetweil @tejaso
          @tejaso also, can you paste the url into your browser while MagicMirror is running to prove you can access it via the MagicMirror web server.
          i have a 100 ics files in the default/calendar folder (used for testing)
